> push rhod, seal replacement
914itis
post Oct 18 2010, 10:28 PM
looking for instructions on push rod replacement with pictures.
VaccaRabite
post Oct 25 2010, 09:18 AM
En Garde!
Yeah, I got it last night.
If you are driving around at 34degrees advanced, you are over advanced on that 1.7 and it could lead to issues up to and including melted pistons or broken cranks due to detonation.
With the vacuum tubes removed, your timing should be set to 27 degrees on a stock 1.7. Replace the vac tubes before you go driving... With the factory advance, you may loose some of the pep the engine has, as advance is one of the ways you can tune in power - but that power comes at the price of more heat and heat will kill an air cooled engine fast.
with the leaks fixed and the timing set you should be able to drive the car like you stole it and have it come back asking for more.
Zach
ppetion   push rhod   Oct 18 2010, 10:28 PM
Vacca Rabite   Not hard to do, and you can do it with the engine ...   Oct 19 2010, 09:30 AM
ppetion   looking for instructions on push rod replacement ...   Oct 19 2010, 11:10 AM
type47   Go Zach! The only thing I would add is when re...   Oct 19 2010, 11:17 AM
Cevan   I used thread sealant (Permatex high temp) on the ...   Oct 19 2010, 11:26 AM
stugray   If it is just one pushrod, you can replace it with...   Oct 19 2010, 11:34 AM
Racer Chris   If it is just one pushrod, you can replace it wit...   Oct 19 2010, 12:12 PM
stugray   LOL! "That would work if he had a Type 1 ...   Oct 19 2010, 10:18 PM
realred914   :sawzall: ditto on use of viton material o-rings i...   Oct 20 2010, 09:52 AM
ppetion   :sawzall: ditto on use of viton material o-rings ...   Oct 23 2010, 05:48 PM
Cap'n Krusty   You may have a problem here. Before we get to t...   Oct 23 2010, 06:34 PM
ppetion   You may have a problem here. Before we get to ...   Oct 23 2010, 09:19 PM
ppetion   You may have a problem here. Before we get to...   Oct 23 2010, 09:22 PM
Cevan   As for the poster who used sealant, that's a ...   Oct 25 2010, 04:44 PM
Vacca Rabite   If you ran the engine for 30 minutes and had no le...   Oct 23 2010, 10:11 PM
ppetion   If you ran the engine for 30 minutes and had no l...   Oct 23 2010, 10:34 PM
Vacca Rabite   I use Brad Penn 20w50. I can't find it locally...   Oct 23 2010, 10:37 PM
ppetion   I use Brad Penn 20w50. I can't find it locall...   Oct 23 2010, 10:48 PM
Vacca Rabite   This is another one of those cans of worms that fo...   Oct 24 2010, 07:50 AM
ppetion   This is another one of those cans of worms that f...   Oct 24 2010, 07:33 PM
ppetion   This is another one of those cans of worms that ...   Oct 24 2010, 07:43 PM
Vacca Rabite   4 quarts for a stock motor. Just make sure that w...   Oct 25 2010, 06:52 AM
ppetion   4 quarts for a stock motor. Just make sure that ...   Oct 25 2010, 08:53 AM
Vacca Rabite   Yeah, I got it last night. If you are driving arou...   Oct 25 2010, 09:18 AM
ppetion   Yeah, I got it last night. If you are driving aro...   Oct 25 2010, 09:30 AM
Vacca Rabite   your dizzy may not be a vac advance dizzy. Yes, I...   Oct 25 2010, 09:41 AM
ppetion   your dizzy may not be a vac advance dizzy. Yes, ...   Oct 25 2010, 04:35 PM
ppetion   I did not understand your last post Cap'n   Oct 25 2010, 05:34 PM
- Lo-Fi Version Time is now: 12th October 2026 - 05:41 AM
