> Can my 914 run on a 14v battery?, Will it tolerate it?
Rod
post Oct 27 2010, 03:38 PM
Region Association: England
I'm into my hi end car audio and I have a 14v agm battery - would I be able to use this in the 914?
benalishhero
post Oct 27 2010, 03:53 PM
I say you would have an amp issue though.
Rod
post Oct 27 2010, 03:55 PM
QUOTE(benalishhero @ Oct 27 2010, 10:53 PM) *
No thats the point, my McIntosh amps are designed to run 14v. I run them on teh bench from a 14.2v power supply and they are better at the higher voltage tbh!
Rod   Can my 914 run on a 14v battery?   Oct 27 2010, 03:38 PM
benalishhero   I say you would have an amp issue though.   Oct 27 2010, 03:53 PM
Rod   I say you would have an amp issue though. No th...   Oct 27 2010, 03:55 PM
underthetire   Don't see why not. Charging system is ~13.8 wh...   Oct 27 2010, 04:12 PM
Rod   No, not lithium - they are sealed lead acid batte...   Oct 27 2010, 04:16 PM
jsayre914   I have been running dual kinetik batteries for som...   Oct 27 2010, 04:31 PM
Rod   I have been running dual kinetik batteries for so...   Oct 27 2010, 04:43 PM
jsayre914   [quote name='jsayre914' post='1387568' date='Oct ...   Oct 28 2010, 12:47 PM
windforfun   Don't see why not. Charging system is ~13.8 w...   Oct 27 2010, 04:44 PM
kg6dxn   Many racers run 16 Volt dual tap batteries (12V/16...   Oct 27 2010, 06:48 PM
monkeyboy   How much more power are you getting at 14v? Is it ...   Oct 28 2010, 12:24 PM
kg6dxn   How much more power are you getting at 14v? Is it...   Oct 28 2010, 01:07 PM
windforfun   I sort of agree, but remember that your amps aren...   Oct 28 2010, 01:48 PM
mskala   It's been a while since I've had a -4, but...   Oct 28 2010, 02:31 PM
Rod   It's been a while since I've had a -4, bu...   Oct 28 2010, 02:53 PM
jsayre914   Oh and to the other nutter with all the Phoenix ...   Oct 28 2010, 03:17 PM
windforfun   Do you use "pi" filters to eliminate eng...   Oct 28 2010, 03:01 PM
Rod   Do you use "pi" filters to eliminate en...   Oct 28 2010, 03:12 PM
windforfun   Do you use "pi" filters to eliminate e...   Oct 28 2010, 03:45 PM
Rod   [quote name='Rod' post='1388009' date='Oct 28 201...   Oct 28 2010, 03:55 PM
windforfun   [quote name='Rod' post='1388009' date='Oct 28 20...   Oct 28 2010, 04:03 PM
Rod   Wow!!! Very cool!!! Got...   Oct 28 2010, 04:13 PM
windforfun   Wow!!! Very cool!!! Go...   Oct 28 2010, 04:22 PM
messix   here ya go. just need to do same fab work to make ...   Oct 28 2010, 03:18 PM
messix   here ya go. just need to do same fab work to make ...   Oct 28 2010, 03:20 PM
Rod   here ya go. just need to do same fab work to make...   Oct 28 2010, 03:34 PM
messix   prolly not. go check over on the samba and see if...   Oct 28 2010, 03:36 PM
stugray   Rod, "So anyone that has a cap that says it ...   Oct 28 2010, 04:22 PM
Rod   Rod, "So anyone that has a cap that says it...   Oct 28 2010, 04:31 PM
jsayre914   :agree: You dont need a cap, but an extra batter...   Oct 28 2010, 04:35 PM
Rod   :agree: You dont need a cap, but an extra batte...   Oct 28 2010, 04:39 PM
windforfun   I use KEFs & Tannoys at home. I just don...   Oct 28 2010, 04:43 PM
windforfun   This is as far as I got.   Oct 28 2010, 04:45 PM
kg6dxn   The theory behind the "stiffening Cap" i...   Oct 28 2010, 07:09 PM
Cap'n Krusty   Your FI control unit doesn't like either low o...   Oct 28 2010, 07:14 PM
windforfun   Most interesting. You guys know your shit.   Oct 28 2010, 07:22 PM
- Lo-Fi Version Time is now: 10th June 2026 - 10:24 PM
