> Can my 914 run on a 14v battery?, Will it tolerate it?
Rod
post Oct 27 2010, 03:38 PM
Region Association: England
I'm into my hi end car audio and I have a 14v agm battery - would I be able to use this in the 914?
mskala
post Oct 28 2010, 02:31 PM
R
It's been a while since I've had a -4, but if your voltage regulator is the
old mechanical type, you can tune it to 15.5~16V by bending a tab.
Rod
post Oct 28 2010, 02:53 PM
QUOTE(mskala @ Oct 28 2010, 09:31 PM) *
Really i'd like to know more...
To all those that don't believe - yes amps make heat, of course they do, but they are also far more efficient with a higher voltage input, so the effort involved in getting a couple more volts input is well worth it.. When the alt is running in a car the battery is basically not used and the voltage supplied is (from the standard alt) 13.6 volts - shut the engine down and the voltage drops instantly to 12.5/6/4 whatever your battery is capable of. If you are involved in sound competitions as I am, keeping the voltage up is really important as the system is judged without the engine running, so the better the voltage supply and more constant the better. Going off topic slightly, some people use caps to keep the voltage from dropping, but you can tell everyone yo know that these are a waste of time as the problem in a car audio system is always the wiring to and from the battery - If the lights dim then it is most probably the negative wire because it is of a smaller awg to the supply wire, therefore causing a bottleneck in the circuit. Put a cap in and yes, it will supply the power needed, but the old wiring circuit still needs to supply the cap with its power, and through the smaller negative wire it will still struggle to circuit properly. So anyone that has a cap that says it improves their sound system you can now inform them of their weaknesses!
Anyway back on topic - a very interesting discussion has evolved and I look forward to other opinions... Oh and to the other nutter with all the Phoenix Gold equipment in his car - I now have two McIntosh amps in the car, ID horns and EMIT tweeters - Sounding amazing!!! Better than my home hifi (IMG:style_emoticons/default/piratenanner.gif)
Rod   Can my 914 run on a 14v battery?   Oct 27 2010, 03:38 PM
benalishhero   I say you would have an amp issue though.   Oct 27 2010, 03:53 PM
Rod   I say you would have an amp issue though. No th...   Oct 27 2010, 03:55 PM
underthetire   Don't see why not. Charging system is ~13.8 wh...   Oct 27 2010, 04:12 PM
Rod   No, not lithium - they are sealed lead acid batte...   Oct 27 2010, 04:16 PM
jsayre914   I have been running dual kinetik batteries for som...   Oct 27 2010, 04:31 PM
Rod   I have been running dual kinetik batteries for so...   Oct 27 2010, 04:43 PM
jsayre914   [quote name='jsayre914' post='1387568' date='Oct ...   Oct 28 2010, 12:47 PM
windforfun   Don't see why not. Charging system is ~13.8 w...   Oct 27 2010, 04:44 PM
kg6dxn   Many racers run 16 Volt dual tap batteries (12V/16...   Oct 27 2010, 06:48 PM
monkeyboy   How much more power are you getting at 14v? Is it ...   Oct 28 2010, 12:24 PM
kg6dxn   How much more power are you getting at 14v? Is it...   Oct 28 2010, 01:07 PM
windforfun   I sort of agree, but remember that your amps aren...   Oct 28 2010, 01:48 PM
mskala   It's been a while since I've had a -4, but...   Oct 28 2010, 02:31 PM
Rod   It's been a while since I've had a -4, bu...   Oct 28 2010, 02:53 PM
jsayre914   Oh and to the other nutter with all the Phoenix ...   Oct 28 2010, 03:17 PM
windforfun   Do you use "pi" filters to eliminate eng...   Oct 28 2010, 03:01 PM
Rod   Do you use "pi" filters to eliminate en...   Oct 28 2010, 03:12 PM
windforfun   Do you use "pi" filters to eliminate e...   Oct 28 2010, 03:45 PM
Rod   [quote name='Rod' post='1388009' date='Oct 28 201...   Oct 28 2010, 03:55 PM
windforfun   [quote name='Rod' post='1388009' date='Oct 28 20...   Oct 28 2010, 04:03 PM
Rod   Wow!!! Very cool!!! Got...   Oct 28 2010, 04:13 PM
windforfun   Wow!!! Very cool!!! Go...   Oct 28 2010, 04:22 PM
messix   here ya go. just need to do same fab work to make ...   Oct 28 2010, 03:18 PM
messix   here ya go. just need to do same fab work to make ...   Oct 28 2010, 03:20 PM
Rod   here ya go. just need to do same fab work to make...   Oct 28 2010, 03:34 PM
messix   prolly not. go check over on the samba and see if...   Oct 28 2010, 03:36 PM
stugray   Rod, "So anyone that has a cap that says it ...   Oct 28 2010, 04:22 PM
Rod   Rod, "So anyone that has a cap that says it...   Oct 28 2010, 04:31 PM
jsayre914   :agree: You dont need a cap, but an extra batter...   Oct 28 2010, 04:35 PM
Rod   :agree: You dont need a cap, but an extra batte...   Oct 28 2010, 04:39 PM
windforfun   I use KEFs & Tannoys at home. I just don...   Oct 28 2010, 04:43 PM
windforfun   This is as far as I got.   Oct 28 2010, 04:45 PM
kg6dxn   The theory behind the "stiffening Cap" i...   Oct 28 2010, 07:09 PM
Cap'n Krusty   Your FI control unit doesn't like either low o...   Oct 28 2010, 07:14 PM
windforfun   Most interesting. You guys know your shit.   Oct 28 2010, 07:22 PM
- Lo-Fi Version Time is now: 10th June 2026 - 10:26 PM
