| Rod |
Oct 27 2010, 03:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I'm into my hi end car audio and I have a 14v agm battery - would I be able to use this in the 914?
| messix |
Oct 28 2010, 03:20 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
here ya go. just need to do same fab work to make it work,
http://www.jegs.com/p/Powermaster/Powermas...042142/10002/-1 |
| Rod |
Oct 28 2010, 03:34 PM
here ya go. just need to do same fab work to make it work, http://www.jegs.com/p/Powermaster/Powermas...042142/10002/-1 Are any of those bolt in?? (IMG:style_emoticons/default/blink.gif) |
Rod Can my 914 run on a 14v battery? Oct 27 2010, 03:38 PM
benalishhero I say you would have an amp issue though. Oct 27 2010, 03:53 PM
Rod
No th... Oct 27 2010, 03:55 PM
underthetire Don't see why not. Charging system is ~13.8 wh... Oct 27 2010, 04:12 PM
Rod No, not lithium - they are sealed lead acid batte... Oct 27 2010, 04:16 PM
jsayre914 I have been running dual kinetik batteries for som... Oct 27 2010, 04:31 PM
Rod
I have been running dual kinetik batteries for so... Oct 27 2010, 04:43 PM
jsayre914
[quote name='jsayre914' post='1387568' date='Oct ... Oct 28 2010, 12:47 PM
windforfun
Don't see why not. Charging system is ~13.8 w... Oct 27 2010, 04:44 PM
kg6dxn Many racers run 16 Volt dual tap batteries (12V/16... Oct 27 2010, 06:48 PM
monkeyboy How much more power are you getting at 14v? Is it ... Oct 28 2010, 12:24 PM
kg6dxn
How much more power are you getting at 14v? Is it... Oct 28 2010, 01:07 PM
windforfun I sort of agree, but remember that your amps aren... Oct 28 2010, 01:48 PM
mskala It's been a while since I've had a -4, but... Oct 28 2010, 02:31 PM
Rod
It's been a while since I've had a -4, bu... Oct 28 2010, 02:53 PM
jsayre914
Oh and to the other nutter with all the Phoenix ... Oct 28 2010, 03:17 PM
windforfun Do you use "pi" filters to eliminate eng... Oct 28 2010, 03:01 PM
Rod
Do you use "pi" filters to eliminate en... Oct 28 2010, 03:12 PM
windforfun
Do you use "pi" filters to eliminate e... Oct 28 2010, 03:45 PM
Rod
[quote name='Rod' post='1388009' date='Oct 28 201... Oct 28 2010, 03:55 PM
windforfun
[quote name='Rod' post='1388009' date='Oct 28 20... Oct 28 2010, 04:03 PM
Rod
Wow!!! Very cool!!! Got... Oct 28 2010, 04:13 PM
windforfun
Wow!!! Very cool!!! Go... Oct 28 2010, 04:22 PM
messix here ya go. just need to do same fab work to make ... Oct 28 2010, 03:18 PM
messix prolly not.
go check over on the samba and see if... Oct 28 2010, 03:36 PM
stugray Rod,
"So anyone that has a cap that says it ... Oct 28 2010, 04:22 PM
Rod
Rod,
"So anyone that has a cap that says it... Oct 28 2010, 04:31 PM
jsayre914 :agree:
You dont need a cap, but an extra batter... Oct 28 2010, 04:35 PM
Rod
:agree:
You dont need a cap, but an extra batte... Oct 28 2010, 04:39 PM
windforfun I use KEFs & Tannoys at home. I just don... Oct 28 2010, 04:43 PM
windforfun This is as far as I got.
Oct 28 2010, 04:45 PM
kg6dxn The theory behind the "stiffening Cap" i... Oct 28 2010, 07:09 PM
Cap'n Krusty Your FI control unit doesn't like either low o... Oct 28 2010, 07:14 PM
windforfun Most interesting. You guys know your shit. Oct 28 2010, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 11:44 PM |
