> Can my 914 run on a 14v battery?, Will it tolerate it?
Rod
post Oct 27 2010, 03:38 PM
Region Association: England
I'm into my hi end car audio and I have a 14v agm battery - would I be able to use this in the 914?
windforfun
post Oct 28 2010, 03:01 PM
Do you use "pi" filters to eliminate engine noise?
Rod
post Oct 28 2010, 03:12 PM
QUOTE(windforfun @ Oct 28 2010, 10:01 PM) *
What the hell are they? (IMG:style_emoticons/default/idea.gif)
No I dont. If you have a system wired correctly first time round without any ground loops you will have zero noise!
windforfun
post Oct 28 2010, 03:45 PM
QUOTE(Rod @ Oct 28 2010, 02:12 PM) *
The schematic looks like the Greek letter pi. Two caps & one choke.
I agree, ground loops are bad, but I disagree about zero noise. Teach me. I've always run into either alternator noise (direct coupled) or ignition noise (RFI perhaps) issues with my sound system installations. Maybe your McIntosh gear has built in power supply filters. Yes? No? Thanks.
Rod
post Oct 28 2010, 03:55 PM
QUOTE(windforfun @ Oct 28 2010, 10:45 PM) *
OK I'm using a HU, a pro audio (Alto UCS Pro) processor, two amps and 7 speakers in my 914 and it's noiseless.. Alt noise is always because of ground loops. A ground loop can be caused by so many things - stargrounding is a good idea and also look at the quality of your grounding points - most people don't want to drill into the chassis so use a seatbelt mounting bolt as the amp grounding point, but was the paint removed prior to bolting up? is it against bare metal... etc and you can then easily see the problems.. I have all my equipment grounded to the battery - HU too - I have run both positive and negative circuits around the car to feed all the equipment ( I hate relying on chassis points as they can corrode, especially on a car as old as me!!) If you want to have a browse of a good car audio forum over in the UK, have a look at www.talkaudio.co.uk - a great site and lots of you Americans are coming over to it as it's got a superb European audience - not that I'm biased as a moderator!
windforfun
post Oct 28 2010, 04:03 PM
QUOTE(Rod @ Oct 28 2010, 02:55 PM) *
Wow!!! Very cool!!! Got any pics? Thanks!!!
(IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/drooley.gif)
Rod
post Oct 28 2010, 04:13 PM
QUOTE(windforfun @ Oct 28 2010, 11:03 PM) *
Sure http://www.talkaudio.co.uk/ipb/index.php/t...install-thread/
Or if you don't want to read thirty pages, look here at just the pics - http://gallery.me.com/rodericdavies#100050...mp;sel= (scroll to the end and work backwards for the most recent stuff...)
Rod   Can my 914 run on a 14v battery?   Oct 27 2010, 03:38 PM
benalishhero   I say you would have an amp issue though.   Oct 27 2010, 03:53 PM
Rod   I say you would have an amp issue though. No th...   Oct 27 2010, 03:55 PM
underthetire   Don't see why not. Charging system is ~13.8 wh...   Oct 27 2010, 04:12 PM
Rod   No, not lithium - they are sealed lead acid batte...   Oct 27 2010, 04:16 PM
jsayre914   I have been running dual kinetik batteries for som...   Oct 27 2010, 04:31 PM
Rod   I have been running dual kinetik batteries for so...   Oct 27 2010, 04:43 PM
jsayre914   [quote name='jsayre914' post='1387568' date='Oct ...   Oct 28 2010, 12:47 PM
windforfun   Don't see why not. Charging system is ~13.8 w...   Oct 27 2010, 04:44 PM
kg6dxn   Many racers run 16 Volt dual tap batteries (12V/16...   Oct 27 2010, 06:48 PM
monkeyboy   How much more power are you getting at 14v? Is it ...   Oct 28 2010, 12:24 PM
kg6dxn   How much more power are you getting at 14v? Is it...   Oct 28 2010, 01:07 PM
windforfun   I sort of agree, but remember that your amps aren...   Oct 28 2010, 01:48 PM
mskala   It's been a while since I've had a -4, but...   Oct 28 2010, 02:31 PM
Rod   It's been a while since I've had a -4, bu...   Oct 28 2010, 02:53 PM
jsayre914   Oh and to the other nutter with all the Phoenix ...   Oct 28 2010, 03:17 PM
windforfun   Do you use "pi" filters to eliminate eng...   Oct 28 2010, 03:01 PM
Rod   Do you use "pi" filters to eliminate en...   Oct 28 2010, 03:12 PM
windforfun   Do you use "pi" filters to eliminate e...   Oct 28 2010, 03:45 PM
Rod   [quote name='Rod' post='1388009' date='Oct 28 201...   Oct 28 2010, 03:55 PM
windforfun   [quote name='Rod' post='1388009' date='Oct 28 20...   Oct 28 2010, 04:03 PM
Rod   Wow!!! Very cool!!! Got...   Oct 28 2010, 04:13 PM
windforfun   Wow!!! Very cool!!! Go...   Oct 28 2010, 04:22 PM
messix   here ya go. just need to do same fab work to make ...   Oct 28 2010, 03:18 PM
messix   here ya go. just need to do same fab work to make ...   Oct 28 2010, 03:20 PM
Rod   here ya go. just need to do same fab work to make...   Oct 28 2010, 03:34 PM
messix   prolly not. go check over on the samba and see if...   Oct 28 2010, 03:36 PM
stugray   Rod, "So anyone that has a cap that says it ...   Oct 28 2010, 04:22 PM
Rod   Rod, "So anyone that has a cap that says it...   Oct 28 2010, 04:31 PM
jsayre914   :agree: You dont need a cap, but an extra batter...   Oct 28 2010, 04:35 PM
Rod   :agree: You dont need a cap, but an extra batte...   Oct 28 2010, 04:39 PM
windforfun   I use KEFs & Tannoys at home. I just don...   Oct 28 2010, 04:43 PM
windforfun   This is as far as I got.   Oct 28 2010, 04:45 PM
kg6dxn   The theory behind the "stiffening Cap" i...   Oct 28 2010, 07:09 PM
Cap'n Krusty   Your FI control unit doesn't like either low o...   Oct 28 2010, 07:14 PM
windforfun   Most interesting. You guys know your shit.   Oct 28 2010, 07:22 PM
- Lo-Fi Version Time is now: 10th June 2026 - 10:25 PM
