| Rod |
Oct 27 2010, 03:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I'm into my hi end car audio and I have a 14v agm battery - would I be able to use this in the 914?
| stugray |
Oct 28 2010, 04:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Rod,
"So anyone that has a cap that says it improves their sound system you can now inform them of their weaknesses!" That is not entirely true.... There are new Ultra-capacitors that can store EXPLOSIVE amounts of energy. If these are placed close to the amplifier, then they can provide extra power when the amp is pulling a lot of current, then re-charge when the amp is pulling less current. They are more than a filter, they are an energy source for load leveling. Stu |
| Rod |
Oct 28 2010, 04:31 PM
Rod, "So anyone that has a cap that says it improves their sound system you can now inform them of their weaknesses!" That is not entirely true.... There are new Ultra-capacitors that can store EXPLOSIVE amounts of energy. If these are placed close to the amplifier, then they can provide extra power when the amp is pulling a lot of current, then re-charge when the amp is pulling less current. They are more than a filter, they are an energy source for load leveling. Stu Sorry, but still a waste of money. SUPERB marketing but a waste of money. An amp has an array of capacitors that store the amount of voltage it needs to produce it's maximum output, adding another cap before these is just a waste of time, the battery that fills this cap either fills the additional caps reserve, or the amps reserve first, now I know which one I would rather have topped up instantaniously, and it's not the external cap. In fact because the battery is desperately trying to fill the external cap the amps' caps are being deprived of the power they need so in fact it is doing the complete opposite to it's purpose.. Some of my friends run 15kw systems doing 20hz at 155db and the only caps in their cars are on their heads (IMG:style_emoticons/default/sunglasses.gif) |
Rod Can my 914 run on a 14v battery? Oct 27 2010, 03:38 PM
benalishhero I say you would have an amp issue though. Oct 27 2010, 03:53 PM
Rod
No th... Oct 27 2010, 03:55 PM
underthetire Don't see why not. Charging system is ~13.8 wh... Oct 27 2010, 04:12 PM
Rod No, not lithium - they are sealed lead acid batte... Oct 27 2010, 04:16 PM
jsayre914 I have been running dual kinetik batteries for som... Oct 27 2010, 04:31 PM
Rod
I have been running dual kinetik batteries for so... Oct 27 2010, 04:43 PM
jsayre914
[quote name='jsayre914' post='1387568' date='Oct ... Oct 28 2010, 12:47 PM
windforfun
Don't see why not. Charging system is ~13.8 w... Oct 27 2010, 04:44 PM
kg6dxn Many racers run 16 Volt dual tap batteries (12V/16... Oct 27 2010, 06:48 PM
monkeyboy How much more power are you getting at 14v? Is it ... Oct 28 2010, 12:24 PM
kg6dxn
How much more power are you getting at 14v? Is it... Oct 28 2010, 01:07 PM
windforfun I sort of agree, but remember that your amps aren... Oct 28 2010, 01:48 PM
mskala It's been a while since I've had a -4, but... Oct 28 2010, 02:31 PM
Rod
It's been a while since I've had a -4, bu... Oct 28 2010, 02:53 PM
jsayre914
Oh and to the other nutter with all the Phoenix ... Oct 28 2010, 03:17 PM
windforfun Do you use "pi" filters to eliminate eng... Oct 28 2010, 03:01 PM
Rod
Do you use "pi" filters to eliminate en... Oct 28 2010, 03:12 PM
windforfun
Do you use "pi" filters to eliminate e... Oct 28 2010, 03:45 PM
Rod
[quote name='Rod' post='1388009' date='Oct 28 201... Oct 28 2010, 03:55 PM
windforfun
[quote name='Rod' post='1388009' date='Oct 28 20... Oct 28 2010, 04:03 PM
Rod
Wow!!! Very cool!!! Got... Oct 28 2010, 04:13 PM
windforfun
Wow!!! Very cool!!! Go... Oct 28 2010, 04:22 PM
messix here ya go. just need to do same fab work to make ... Oct 28 2010, 03:18 PM
messix here ya go. just need to do same fab work to make ... Oct 28 2010, 03:20 PM
Rod
here ya go. just need to do same fab work to make... Oct 28 2010, 03:34 PM
messix prolly not.
go check over on the samba and see if... Oct 28 2010, 03:36 PM
jsayre914 :agree:
You dont need a cap, but an extra batter... Oct 28 2010, 04:35 PM
Rod
:agree:
You dont need a cap, but an extra batte... Oct 28 2010, 04:39 PM
windforfun I use KEFs & Tannoys at home. I just don... Oct 28 2010, 04:43 PM
windforfun This is as far as I got.
Oct 28 2010, 04:45 PM
kg6dxn The theory behind the "stiffening Cap" i... Oct 28 2010, 07:09 PM
Cap'n Krusty Your FI control unit doesn't like either low o... Oct 28 2010, 07:14 PM
windforfun Most interesting. You guys know your shit. Oct 28 2010, 07:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 10:24 PM |
