> 1.8 Rebuild and Modification...
MikeM
post Nov 1 2010, 07:23 PM
Hi all...I've searched the archives but didn't find enough specific info so I'll ask some questions to the general membership.
I have the chance to buy a 1.8 motor really,really cheap. I'll assume it will need a full rebuild, but I have a couple of questions.
Is a 1.8 a good candidate for a rebuild with mods? Larger pistons and cylinders?
Camshaft? Head work? Case work?
Or should I just hold out for another 2.0 liter?
Thoughts??
Thanks in advance.
Mike
Cupomeat
post Nov 1 2010, 08:00 PM
missing my NY 914 in VA
Yes, the 1.8l is a very good candidate for a rebuild with mods.
The real question is how far do you intend to mod the engine?
a few points;
- The 1.8 heads are better flowing (by far) than the 1.7, but not as good as the 2.0.
- The 66mm stroke is smaller than the 71 mm of the 2.0l, BUT putting 96mm pistons on the 1.8 is a slip in fit (no machining) and will get you 1911cc displacement, which is close to the original 2.0l displacement.
- The 66mm rod ends at the crank are larger and last longer than the 2.0l rod bearings.
- the L-Jet FI is a VERY reliable, smooth and simple FI and should be retained if you are keeping the displacement under 2.1 and not looking to mod the cam. IF you are looking to swap tha cam, the L-jet might not handle the overlap (and subsequent pulsing/ vacuum loss).
So, do you have a budget $ or goal hp that you are looking to achieve. Sometimes it is cheaper to hold out, but if the 1,8 is really cheap it is worth picking it up, sometimes for the parts (MANY are shared with the 2.0l motor).
Good luck!
- Lo-Fi Version Time is now: 12th July 2025 - 03:36 PM
