Dam 914 still doesn’t start regularly |
Kevan |
Mar 22 2004, 09:15 PM
Newbie Group: Members Posts: 31 Joined: 5-December 03 From: Paso Robles,ca Member No.: 1,421 |
My 914 still doesn’t start regularly. I turn the key and every time I heir the buzz my guess is the D-Jet fuel pumping and then it might start or nothing happens. Once it starts cranking it will start just fine. Here is a list of what I’ve done. What am I missing??? What could be wrong?
New battery Clean the connections on the battery New ends on the positive wires to the battery New ignition switch Clean and replaced connections on the starter solenoid Cleaned ground strap connections from tranny to trunk Kevan |
majkos |
Mar 24 2004, 03:25 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
It was very hot!(Hot start problem)
Yes I used to have the vapor lock problems,but since I've built a heat shield(Wicked looking) No problems. But back to hot start problems,are you saying I'm going to have starter problem down the road? (IMG:style_emoticons/default/blink.gif) The relay is just a a band-aid for now? (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 09:20 AM |
