Test fitting doors, gap is off, FML |
Gearhead1432 |
Aug 29 2010, 01:50 PM
Member Group: Members Posts: 129 Joined: 21-December 05 From: Altus, OK Member No.: 5,304 Region Association: None |
I have the right side inner rocker all welded up as well as the hell hole and jack post. Is now is the time to test fit the doors before I weld in the door sill and quarter pannel? I think it should be fine. I'm concerned the chassis may have warped and I'd like to be sure before I finish the rest of the welding.
Thanks, Rob |
Gearhead1432 |
Nov 2 2010, 11:58 PM
I managed to fix the passenger side. It now measures the same as it did before I statred cutting it up. The gaps look about the same too. Unfortunatly they are not uniform. Then again, they were never uniform front to back or left to right. I don't think there is any easy way to change that.
-Rob Here are some updated pictures. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:31 PM |
