Relay boards, are they all the same? |
Tom |
Nov 1 2010, 02:25 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Looking to get a used relay board for some testing and repair/renovation. Any reason that any one would work on any car?
I have been thinking that a good place for the hot-no start syndrome is the rivited contacts to trace connections in the relay board. Maybe a good cleaning and then soldering these higher current contacts would make the relay board better.? I think I have read on here that they are all the same, but I'm not sure. What do you think or know? (IMG:style_emoticons/default/screwy.gif) Thanks, Tom |
Joe Owensby |
Nov 3 2010, 07:44 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Clean the bottom of the board very well, removing all the gunk. Then use a dremmel tool with wire brush or burr tool to thoroughly clean both the copper trace and the connection that goes to the top. Then, it will solder very easily. Has to be shiny for the solder to stick. Finally, apply a coating to protect the traces again. You can buy commercial potting compount, I think 3M sells this among others. I have read that other people use Silicon seal or other stuff. JoeO
Lo-Fi Version | Time is now: 7th June 2024 - 12:44 PM |
