Dam 914 still doesn’t start regularly |
Kevan |
Mar 22 2004, 09:15 PM
Newbie Group: Members Posts: 31 Joined: 5-December 03 From: Paso Robles,ca Member No.: 1,421 |
My 914 still doesn’t start regularly. I turn the key and every time I heir the buzz my guess is the D-Jet fuel pumping and then it might start or nothing happens. Once it starts cranking it will start just fine. Here is a list of what I’ve done. What am I missing??? What could be wrong?
New battery Clean the connections on the battery New ends on the positive wires to the battery New ignition switch Clean and replaced connections on the starter solenoid Cleaned ground strap connections from tranny to trunk Kevan |
Dave_Darling |
Mar 24 2004, 09:28 PM
The biiiiiiiiig yellow ones. One of them might have a red stripe on it. Make sure the joint is clean and tight, and use shrink-tubing on it to keep out water and dirt.
--DD |
Lo-Fi Version | Time is now: 11th June 2024 - 09:11 AM |
