| 913B |
Nov 8 2010, 05:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So I ask the FLAPS parts person for fuel line hose and he gives me this. Then I check online with the SAE J30R7 rating stamped on the hose. It says operating PSI is 50 and burst psi is 250.
http://www.goodyearep.com/ProductsDetail.aspx?id=10526 Is it safe ? Perhaps some members with deeper knowledge can confirm?? If so whats with the warning of dont use on FI cars ? Maybe modern FI cars and not the ones like 39 years ago maybe. Thank you all !! Ted (IMG:style_emoticons/default/beerchug.gif) |
| jk76.914 |
Nov 8 2010, 05:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Correct lines are 7mm ID x 3mm wall, with means the OD is 13mm. I've seen this sold as both 7x3 and as 7x13, and it ain't cheap. That 5/16" fuel line is almost 8mm in ID. You may get it to seal with a tight clamp, but it'll too easily leak when it thermal cycles and starts to loose its stretch. Even Goodyear says it isn't for fuel injection.
I've heard of some people using BMW 7.5mm lines, but I'd stick with the right stuff. Too many 914's have burned up because of engine fires, and even the factory did a recall to replace the original cloth-braided 7x12 lines with these. I also wouldn't go with 50 psi working pressure. That doesn't even give you a 2x safety margin.... While you're at it, be sure and get the correct clamps. Standard gear style clamps can cut through the outer skin of the hose, and lead to leaks later, or worse. |
| ChrisFoley |
Nov 8 2010, 06:06 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Correct lines are 7mm ID x 3mm wall, with means the OD is 13mm. I've seen this sold as both 7x3 and as 7x13, and it ain't cheap. That 5/16" fuel line is almost 8mm in ID. Have you ever actually measured the od of the tubes that the fuel hose fits onto? Modern 7.9mm id hose is plenty tight on all the fittings you say need 7mm hose for a proper fit. It will never leak if the correct clamps are used. However, if it isn't rated for FI don't use it for FI. |
| jk76.914 |
Nov 8 2010, 06:27 PM
porsche913b_sp 5/16 Fuel Hose for 1.7 D-Jet Nov 8 2010, 05:10 PM
underthetire Buy the injection hose with the colored liner. Our... Nov 8 2010, 05:24 PM
porsche913b_sp Hmm, thanks for the good advice. Nov 8 2010, 07:17 PM
realred914 5/16 inch is a great fit, wont fail with clamps. ... Nov 8 2010, 07:38 PM
Rotary'14
5/16 inch is a great fit, wont fail with clamps. ... Nov 8 2010, 07:53 PM
realred914
5/16 inch is a great fit, wont fail with clamps.... Nov 8 2010, 08:07 PM
porsche913b_sp So I am back to fuel line replacement project. So ... Dec 11 2010, 08:31 PM
bandjoey I don't know the ratings. A year ago I bought... Dec 11 2010, 11:17 PM
patssle When you guys say the R7 degrades because of the f... Dec 11 2010, 11:29 PM
underthetire Well, the one piece I replaced with the R7 stuff s... Dec 12 2010, 12:17 AM
dangrouche R9 rated hose; cut by the foot, cost about $7... Dec 12 2010, 01:35 AM
AvalonFal I posted this pic a while back, but here's an ... Dec 12 2010, 11:01 AM
realred914
I posted this pic a while back, but here's an... Dec 12 2010, 11:21 AM
AvalonFal
I posted this pic a while back, but here's a... Dec 13 2010, 08:53 AM
76-914 :popcorn: Dec 12 2010, 12:39 PM
jk76.914 Does anybody make the elbow hoses to the fuel inje... Dec 12 2010, 07:53 PM
jsconst
Does anybody make the elbow hoses to the fuel inj... Feb 4 2011, 12:27 AM
underthetire
Does anybody make the elbow hoses to the fuel in... Feb 4 2011, 10:07 AM
type11969 Hoses to the fuel injectors are the same hose as e... Dec 12 2010, 08:57 PM
Cupomeat
Hoses to the fuel injectors are the same hose as ... Dec 12 2010, 09:14 PM
porsche913b_sp
Does anybody make the elbow hoses to the fuel inj... Dec 12 2010, 10:36 PM
tod914 Just use a short piece of the R9 line. Next time ... Dec 12 2010, 11:17 PM
jk76.914 Unleaded??? How old IS that hose? Dec 13 2010, 05:36 PM
type11969 Just a heads up, but the blue liner has been disco... Dec 13 2010, 09:02 PM
914_teener
Just a heads up, but the blue liner has been disc... Feb 3 2011, 10:55 PM
porsche913b_sp On a tip from my friend pep boys carrys the SAE 30... Feb 3 2011, 11:30 PM
type11969 Gooodyear stopped using the liner, but the replace... Feb 4 2011, 06:19 AM
underthetire http://www.rockauto.com/catalog/raframecat...64-27... Feb 4 2011, 10:12 AM
76-914 Has anyone w/ FI used the 1/4" SAE 30R9 inste... Feb 4 2011, 10:34 AM
underthetire
Has anyone w/ FI used the 1/4" SAE 30R9 inst... Feb 4 2011, 11:42 AM
76-914 Being the hard headed individual that I am, I wrot... Feb 4 2011, 02:04 PM
elmonte Found this on-line. Great price, but you have to b... Feb 4 2011, 02:16 PM
SLITS
Found this on-line. Great price, but you have to ... Feb 5 2011, 09:11 AM
elmonte
[quote name='elmonte' post='1427082' date='Feb 4 ... Feb 5 2011, 01:58 PM
ELLIOTT wonder how many feet in the roll? Feb 4 2011, 02:45 PM
elmonte
25 ft Feb 4 2011, 02:57 PM
underthetire Great price. Might have to pick up a roll next tim... Feb 4 2011, 03:41 PM
Rex-n-effect Go to your local VW or Audi dealer and buy part # ... Feb 4 2011, 04:46 PM
nathansnathan
Go to your local VW or Audi dealer and buy part #... Feb 4 2011, 05:18 PM
jim_hoyland How many feet does a typical FI car require, inclu... Feb 4 2011, 05:43 PM
realred914 the 30R9 is still lined with a flouropolymer, some... Feb 4 2011, 06:26 PM
914_teener
the 30R9 is still lined with a flouropolymer, som... Feb 4 2011, 06:41 PM
76-914 When you say a roll you don't mention which si... Feb 4 2011, 06:50 PM
fasthonda I found the best deal for goodyear 30R9 @ Greasec... Feb 4 2011, 08:29 PM
jimkelly see this ??
http://www.914world.com/bbs2/index.ph... Feb 5 2011, 10:55 AM
76-914 Just a quick update. I have been in touch w/ the f... Feb 15 2011, 10:35 AM
jim_hoyland Has anyone verified that non-30R9 fuel hose actual... Feb 15 2011, 11:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:49 PM |
