> turn signal help please, for the electically in-experienced..
MrHyde
post Nov 8 2010, 12:40 PM
Background:
The PO of my 73' 2.0L said that he never actually drove the car. He picked it up to restore and then got more involved with his MG's ( he has a sweet MGB with a mustang drivetrain in it , and a couple more under covers) .. anyways.. the turn signals dont work.. in the glove box i found an extra relay socket, and a 4 prong relay... hanging out under the fuse board is another of the same socket I found in the glove box.. I'm assuming that some PO wired this thing in to get the turn signals working.. the signal lights all come on when I turn the headlights on ( tail lights AND all the turn signals ) when fliping the turn signal switch, nothing happens.. no dash lights.. no flashing...
question...
I've never really needed to use a multimeter before, so i'm totally inexperienced with this.. I want to know how to find out if this socket is infact for the turn signals ( so I can just get a turn signal relay ) or find out where to check the wiring with the multimeter to see where the disconnect is happening..
Since My shoulder is out of commission right now, I cant do any heavy work at all, but testing a circut with a multimeter is doable. I've downloaded a couple wiring diagrams, but it all looks a bit greek to me right now...
Thanks in advance for the help !
pcar916
post Nov 9 2010, 09:56 AM
Is that a Lola?
Let the wire colors take you to all devices. Look at the factory diagrams, find the wire colors that go to the devices you want and follow the wires to there destination. It'll take some time for you to get used to it. Expect it. One more thing.
If your shoulder it screwed up then
1. take the seat out and the steering wheel off
2. Put a big blanket on the floorboard
Under the dash will be more comfortable... and ignore the empty socket on the fuse panel unless the wire color points to one in the circuits you have to work on.
MrHyde   turn signal help please   Nov 8 2010, 12:40 PM
pcar916   Before attacking relays do the natural thing and h...   Nov 8 2010, 04:13 PM
windforfun   Do you know basic electricity? Ohm's law? Ca...   Nov 8 2010, 09:41 PM
MrHyde   I can follow the schematic as in " this goes...   Nov 9 2010, 07:04 AM
type47   I have has the power coming from the battery, to...   Nov 9 2010, 07:37 AM
MrHyde   this is the diagram I'm going off of http://w...   Nov 9 2010, 08:13 AM
pcar916   That drawing screwed me up one time. It may be for...   Nov 9 2010, 08:29 AM
MrHyde   It says right on it 1970-1973, Mines a '73... ...   Nov 9 2010, 08:46 AM
MrHyde   more info an questions... when I turn the headlig...   Nov 9 2010, 09:02 AM
76-914   I wish that I could tell you how many hours I spen...   Nov 9 2010, 09:28 AM
MrHyde   "this could take a couple weeks"... Tim...   Nov 9 2010, 09:36 AM
MrHyde   here's teh pic.. dont mind the cheezy speake ...   Nov 9 2010, 09:50 AM
type47   so you can see the socket for the flasher relay (...   Nov 9 2010, 10:37 AM
pcar916   Things unplugged may create a "floating groun...   Nov 9 2010, 09:51 AM
pcar916   Let the wire colors take you to all devices. Look ...   Nov 9 2010, 09:56 AM
MrHyde   here is s pic of the relay the PO gave me, he said...   Nov 9 2010, 09:59 AM
pcar916   Look under the dash above where the fuse panel att...   Nov 9 2010, 10:04 AM
MrHyde   I looked up under where teh fuse panel is mounted....   Nov 9 2010, 10:13 AM
DJKnut   MrHyde... I've found that in cars, when light...   Nov 9 2010, 10:17 AM
MrHyde   thank DJKnut ! I have a diagram I printed fr...   Nov 9 2010, 10:27 AM
MrHyde   I've had some success.... I pluged that relay...   Nov 9 2010, 10:46 AM
pcar916   I've had some success.... I pluged that rela...   Nov 9 2010, 10:58 AM
pcar916   Oh yes, the connector attached to your signal swit...   Nov 9 2010, 11:07 AM
MrHyde   Well... I guess I'm going to have to get a han...   Nov 9 2010, 01:41 PM
pcar916   I'll have a look for this connector and see i...   Nov 9 2010, 03:33 PM
luskesq   I used I believe a 1" or 1 1/8 deep socket wh...   Nov 9 2010, 02:24 PM
windforfun   Don't forget that you can slide the seat all t...   Nov 9 2010, 05:16 PM
Spoke   The schematics in the repair manuals are a bitch t...   Nov 9 2010, 09:08 PM
pcar916   Simple is gooder than not... I like targeted syst...   Nov 10 2010, 11:19 AM
MrHyde   so if I read this correct.. now that i've unpl...   Nov 10 2010, 12:58 PM
jt914-6   In Ron's drawing 4-5 is left....5-6 is right.....   Nov 10 2010, 02:24 PM
MrHyde   oops.. got the right n left backwards... sorry   Nov 10 2010, 02:39 PM
pcar916   JT is correct on the procedure... only difference ...   Nov 11 2010, 09:01 AM
MrHyde   Thanks guys.. the switch is good.... signals stil...   Nov 11 2010, 01:25 PM
pcar916   the switch is good.... signals still dont work.....   Nov 11 2010, 02:15 PM
MrHyde   nope ... no new relay yet... gonna have to order o...   Nov 11 2010, 03:01 PM
DJKnut   The turn lights on solid (L or R..) without the ke...   Nov 11 2010, 04:29 PM
bandjoey   Grounds Grounds Grounds on the bulb sockets, wire ...   Nov 11 2010, 11:11 PM
MrHyde   So I've had success ! Kind of... I orde...   Nov 24 2010, 07:40 PM
jk76.914   I figured this out a while back. I wrote up how i...   Nov 24 2010, 07:58 PM
MrHyde   any idea why the new relay wouldnt work then ?? gr...   Nov 24 2010, 08:17 PM
jk76.914   any idea why the new relay wouldnt work then ?? g...   Nov 24 2010, 09:20 PM
MrHyde   Its a Wittrin relay part # 013309. 4 prong and ...   Nov 25 2010, 06:39 AM
jk76.914   Its a Wittrin relay part # 013309. 4 prong and...   Nov 26 2010, 08:08 AM
Spoke   Back on Nov 9, post #21, you mentioned that the ha...   Nov 26 2010, 09:40 AM
MrHyde   turn signal, hazard lights marker lights all work ...   Nov 26 2010, 10:56 AM
Spoke   Both indicator lights coming on is common with the...   Nov 26 2010, 11:10 AM
jimkelly   spoke my 1972 car has the problem of both directi...   Oct 25 2013, 06:51 PM
Spoke   spoke my 1972 car has the problem of both direct...   Oct 25 2013, 07:00 PM
jimkelly   thank you :thumbsup:   Oct 25 2013, 07:24 PM
- Lo-Fi Version Time is now: 25th October 2026 - 11:13 AM
