| MrHyde |
Nov 8 2010, 12:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Background:
The PO of my 73' 2.0L said that he never actually drove the car. He picked it up to restore and then got more involved with his MG's ( he has a sweet MGB with a mustang drivetrain in it , and a couple more under covers) .. anyways.. the turn signals dont work.. in the glove box i found an extra relay socket, and a 4 prong relay... hanging out under the fuse board is another of the same socket I found in the glove box.. I'm assuming that some PO wired this thing in to get the turn signals working.. the signal lights all come on when I turn the headlights on ( tail lights AND all the turn signals ) when fliping the turn signal switch, nothing happens.. no dash lights.. no flashing... question... I've never really needed to use a multimeter before, so i'm totally inexperienced with this.. I want to know how to find out if this socket is infact for the turn signals ( so I can just get a turn signal relay ) or find out where to check the wiring with the multimeter to see where the disconnect is happening.. Since My shoulder is out of commission right now, I cant do any heavy work at all, but testing a circut with a multimeter is doable. I've downloaded a couple wiring diagrams, but it all looks a bit greek to me right now... Thanks in advance for the help ! |
| DJKnut |
Nov 9 2010, 10:17 AM
Newbie ![]() Group: Members Posts: 11 Joined: 21-August 10 From: Bellingham, Washington Member No.: 12,085 Region Association: Pacific Northwest |
MrHyde... I've found that in cars, when lights seem to act very strangely.. like yours are doing... it's very often due to bad grounds... a valid power source will back feed through other bulbs to find a way home, and light up everything it passes through.. at least partly..!! On the flow diagram, at the bottom, is the ground connection... with a circled number... the index for those diagrams will tell you where that ground number is actually located... most of these are steel tabs welded to the body, and often rust and loose connection... track your locations down and clean them up, and see if things act any differently.... That may eliminate some of the confusion, and show you where the true problem is... Remember, the flasher function responds to load so if you don't have good bulb connections they won't even try to work... Pull lenses and clean bulb sockets.. you could even make up a jumper wire to the battery (or any battery..) to verify that each lamp-socket is connecting and working properly... VW wiring is really pretty good ( especially when compared to British cars..!!) and most of my problems have ended up being connections... Good luck!! Dave
MrHyde turn signal help please Nov 8 2010, 12:40 PM
pcar916 Before attacking relays do the natural thing and h... Nov 8 2010, 04:13 PM
windforfun Do you know basic electricity? Ohm's law? Ca... Nov 8 2010, 09:41 PM
MrHyde I can follow the schematic as in " this goes... Nov 9 2010, 07:04 AM
type47
I have has the power coming from the battery, to... Nov 9 2010, 07:37 AM
MrHyde this is the diagram I'm going off of
http://w... Nov 9 2010, 08:13 AM
pcar916 That drawing screwed me up one time. It may be for... Nov 9 2010, 08:29 AM
MrHyde It says right on it 1970-1973, Mines a '73... ... Nov 9 2010, 08:46 AM
MrHyde more info an questions...
when I turn the headlig... Nov 9 2010, 09:02 AM
76-914 I wish that I could tell you how many hours I spen... Nov 9 2010, 09:28 AM
MrHyde "this could take a couple weeks"... Tim... Nov 9 2010, 09:36 AM
MrHyde here's teh pic.. dont mind the cheezy speake ... Nov 9 2010, 09:50 AM
type47
so you can see the socket for the flasher relay (... Nov 9 2010, 10:37 AM
pcar916 Things unplugged may create a "floating groun... Nov 9 2010, 09:51 AM
pcar916 Let the wire colors take you to all devices. Look ... Nov 9 2010, 09:56 AM
MrHyde here is s pic of the relay the PO gave me, he said... Nov 9 2010, 09:59 AM
pcar916 Look under the dash above where the fuse panel att... Nov 9 2010, 10:04 AM
MrHyde I looked up under where teh fuse panel is mounted.... Nov 9 2010, 10:13 AM
MrHyde thank DJKnut ! I have a diagram I printed fr... Nov 9 2010, 10:27 AM
MrHyde I've had some success....
I pluged that relay... Nov 9 2010, 10:46 AM
pcar916
I pluged that rela... Nov 9 2010, 10:58 AM
pcar916 Oh yes, the connector attached to your signal swit... Nov 9 2010, 11:07 AM
MrHyde Well... I guess I'm going to have to get a han... Nov 9 2010, 01:41 PM
pcar916
I'll have a look for this connector and see i... Nov 9 2010, 03:33 PM
luskesq I used I believe a 1" or 1 1/8 deep socket wh... Nov 9 2010, 02:24 PM
windforfun Don't forget that you can slide the seat all t... Nov 9 2010, 05:16 PM
Spoke The schematics in the repair manuals are a bitch t... Nov 9 2010, 09:08 PM
pcar916 Simple is gooder than not... I like targeted syst... Nov 10 2010, 11:19 AM
MrHyde so if I read this correct.. now that i've unpl... Nov 10 2010, 12:58 PM
jt914-6 In Ron's drawing 4-5 is left....5-6 is right..... Nov 10 2010, 02:24 PM
MrHyde oops.. got the right n left backwards... sorry Nov 10 2010, 02:39 PM
pcar916 JT is correct on the procedure... only difference ... Nov 11 2010, 09:01 AM
MrHyde Thanks guys.. the switch is good.... signals stil... Nov 11 2010, 01:25 PM
pcar916
the switch is good.... signals still dont work..... Nov 11 2010, 02:15 PM
MrHyde nope ... no new relay yet... gonna have to order o... Nov 11 2010, 03:01 PM
DJKnut The turn lights on solid (L or R..) without the ke... Nov 11 2010, 04:29 PM
bandjoey Grounds Grounds Grounds on the bulb sockets, wire ... Nov 11 2010, 11:11 PM
MrHyde So I've had success ! Kind of...
I orde... Nov 24 2010, 07:40 PM
jk76.914 I figured this out a while back. I wrote up how i... Nov 24 2010, 07:58 PM
MrHyde any idea why the new relay wouldnt work then ?? gr... Nov 24 2010, 08:17 PM
jk76.914
any idea why the new relay wouldnt work then ?? g... Nov 24 2010, 09:20 PM
MrHyde Its a Wittrin relay part # 013309. 4 prong and ... Nov 25 2010, 06:39 AM
jk76.914
Its a Wittrin relay part # 013309. 4 prong and... Nov 26 2010, 08:08 AM
Spoke Back on Nov 9, post #21, you mentioned that the ha... Nov 26 2010, 09:40 AM
MrHyde turn signal, hazard lights marker lights all work ... Nov 26 2010, 10:56 AM
Spoke Both indicator lights coming on is common with the... Nov 26 2010, 11:10 AM
jimkelly spoke
my 1972 car has the problem of both directi... Oct 25 2013, 06:51 PM
Spoke
spoke
my 1972 car has the problem of both direct... Oct 25 2013, 07:00 PM
jimkelly thank you :thumbsup: Oct 25 2013, 07:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th October 2026 - 11:13 AM |
