| MrHyde |
Nov 8 2010, 12:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None |
Background:
The PO of my 73' 2.0L said that he never actually drove the car. He picked it up to restore and then got more involved with his MG's ( he has a sweet MGB with a mustang drivetrain in it , and a couple more under covers) .. anyways.. the turn signals dont work.. in the glove box i found an extra relay socket, and a 4 prong relay... hanging out under the fuse board is another of the same socket I found in the glove box.. I'm assuming that some PO wired this thing in to get the turn signals working.. the signal lights all come on when I turn the headlights on ( tail lights AND all the turn signals ) when fliping the turn signal switch, nothing happens.. no dash lights.. no flashing... question... I've never really needed to use a multimeter before, so i'm totally inexperienced with this.. I want to know how to find out if this socket is infact for the turn signals ( so I can just get a turn signal relay ) or find out where to check the wiring with the multimeter to see where the disconnect is happening.. Since My shoulder is out of commission right now, I cant do any heavy work at all, but testing a circut with a multimeter is doable. I've downloaded a couple wiring diagrams, but it all looks a bit greek to me right now... Thanks in advance for the help ! |
| MrHyde |
Nov 9 2010, 01:41 PM
Well... I guess I'm going to have to get a hand from my wife and pull the seat out so I can see up in there better.. I'll have a look for this connector and see if I can get a reading on it..
Now, my multimeter doesnt have a continuity buzzer, but if what I've been reading serves... I can just set it on the lowers ohn settin... 200ohm i thinks.. and if I get SOMETHING... then its good.. right ? EDIT: Also.. does anyone know the size of the steering wheel hub nut ?? i dont think I have a metric socket that big, I'm going to have to do some shopping on friday.. (IMG:style_emoticons/default/smile.gif) |
| pcar916 |
Nov 9 2010, 03:33 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I'll have a look for this connector and see if I can get a reading on it.. Now, my multimeter doesnt have a continuity buzzer... I can just set it on the lowers ohn settin... That connectors are on the underside near your leg. The black wiring-harness cable connections just pull out from the steering wheel counterparts. It's easy to see if you have the lower dash-pad removed. I don't remember what it's like when the pad is there but it'd be above that. You can put your ohmmeter on the highest setting. There aren't any sensitive components to hurt and you may need the juice. I just snapped a pic of it a minute ago. ![]() |
MrHyde turn signal help please Nov 8 2010, 12:40 PM
pcar916 Before attacking relays do the natural thing and h... Nov 8 2010, 04:13 PM
windforfun Do you know basic electricity? Ohm's law? Ca... Nov 8 2010, 09:41 PM
MrHyde I can follow the schematic as in " this goes... Nov 9 2010, 07:04 AM
type47
I have has the power coming from the battery, to... Nov 9 2010, 07:37 AM
MrHyde this is the diagram I'm going off of
http://w... Nov 9 2010, 08:13 AM
pcar916 That drawing screwed me up one time. It may be for... Nov 9 2010, 08:29 AM
MrHyde It says right on it 1970-1973, Mines a '73... ... Nov 9 2010, 08:46 AM
MrHyde more info an questions...
when I turn the headlig... Nov 9 2010, 09:02 AM
76-914 I wish that I could tell you how many hours I spen... Nov 9 2010, 09:28 AM
MrHyde "this could take a couple weeks"... Tim... Nov 9 2010, 09:36 AM
MrHyde here's teh pic.. dont mind the cheezy speake ... Nov 9 2010, 09:50 AM
type47
so you can see the socket for the flasher relay (... Nov 9 2010, 10:37 AM
pcar916 Things unplugged may create a "floating groun... Nov 9 2010, 09:51 AM
pcar916 Let the wire colors take you to all devices. Look ... Nov 9 2010, 09:56 AM
MrHyde here is s pic of the relay the PO gave me, he said... Nov 9 2010, 09:59 AM
pcar916 Look under the dash above where the fuse panel att... Nov 9 2010, 10:04 AM
MrHyde I looked up under where teh fuse panel is mounted.... Nov 9 2010, 10:13 AM
DJKnut MrHyde... I've found that in cars, when light... Nov 9 2010, 10:17 AM
MrHyde thank DJKnut ! I have a diagram I printed fr... Nov 9 2010, 10:27 AM
MrHyde I've had some success....
I pluged that relay... Nov 9 2010, 10:46 AM
pcar916
I pluged that rela... Nov 9 2010, 10:58 AM
pcar916 Oh yes, the connector attached to your signal swit... Nov 9 2010, 11:07 AM
luskesq I used I believe a 1" or 1 1/8 deep socket wh... Nov 9 2010, 02:24 PM
windforfun Don't forget that you can slide the seat all t... Nov 9 2010, 05:16 PM
Spoke The schematics in the repair manuals are a bitch t... Nov 9 2010, 09:08 PM
pcar916 Simple is gooder than not... I like targeted syst... Nov 10 2010, 11:19 AM
MrHyde so if I read this correct.. now that i've unpl... Nov 10 2010, 12:58 PM
jt914-6 In Ron's drawing 4-5 is left....5-6 is right..... Nov 10 2010, 02:24 PM
MrHyde oops.. got the right n left backwards... sorry Nov 10 2010, 02:39 PM
pcar916 JT is correct on the procedure... only difference ... Nov 11 2010, 09:01 AM
MrHyde Thanks guys.. the switch is good.... signals stil... Nov 11 2010, 01:25 PM
pcar916
the switch is good.... signals still dont work..... Nov 11 2010, 02:15 PM
MrHyde nope ... no new relay yet... gonna have to order o... Nov 11 2010, 03:01 PM
DJKnut The turn lights on solid (L or R..) without the ke... Nov 11 2010, 04:29 PM
bandjoey Grounds Grounds Grounds on the bulb sockets, wire ... Nov 11 2010, 11:11 PM
MrHyde So I've had success ! Kind of...
I orde... Nov 24 2010, 07:40 PM
jk76.914 I figured this out a while back. I wrote up how i... Nov 24 2010, 07:58 PM
MrHyde any idea why the new relay wouldnt work then ?? gr... Nov 24 2010, 08:17 PM
jk76.914
any idea why the new relay wouldnt work then ?? g... Nov 24 2010, 09:20 PM
MrHyde Its a Wittrin relay part # 013309. 4 prong and ... Nov 25 2010, 06:39 AM
jk76.914
Its a Wittrin relay part # 013309. 4 prong and... Nov 26 2010, 08:08 AM
Spoke Back on Nov 9, post #21, you mentioned that the ha... Nov 26 2010, 09:40 AM
MrHyde turn signal, hazard lights marker lights all work ... Nov 26 2010, 10:56 AM
Spoke Both indicator lights coming on is common with the... Nov 26 2010, 11:10 AM
jimkelly spoke
my 1972 car has the problem of both directi... Oct 25 2013, 06:51 PM
Spoke
spoke
my 1972 car has the problem of both direct... Oct 25 2013, 07:00 PM
jimkelly thank you :thumbsup: Oct 25 2013, 07:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th October 2026 - 11:13 AM |
