> New GPRBar SWAY BAR Kinda Cool, I Think, 19mm sway bar on sale now
hwgunner
post Feb 24 2010, 03:17 PM
914 Parts @ Discount Prices 800.321.5432
So i have been thinking about this for a long time and I finally took the plunge. this is what i came up with.
Introducing the new GPRBar for Porsche 911’s and 914’s. A German Parts & Restoration exclusive, designed by Tarett Engineering, the NEW GPRBar is 19.4mm equivalent and is a modular design that can be used as a complete system or can be purchased separately as the BarKit (the bar and bearing blocks) to install with your stock sway bar arms and drop links or the ArmKit (the adjustable sway bar arms and adjustable drop links) to install with your stock through body sway bar. These light weight hollow sway bars are half the weight of a solid bar with the same stiffness. The bar itself is made from aircraft-quality 4130 chrome moly steel, heat treated and zinc plated for strength and durability. The adjustable arms and adjustable drop links are CNC machined from aircraft-quality 6061-T6 Aluminum for its strength and durability. Correctly sized, precision, Teflon-lined rod-ends mean smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends. Thermoplastic bushings impregnated with Teflon and reinforced with Kevlar provide smooth operation, long life, and high resistance to deflecting under heavy loading. All necessary hardware is provided in zinc plated metric class 8.8.
GPRBar $475.00
BarKit $250.00
ArmKit $250.00
Also available for the Porsche 911 is the rear GPRBar. Same great materials as above with a 19.4mm equivalent bar. This is a complete sway bar set up.
(911 Rear GPRBar $475)
DanT
post Nov 9 2010, 09:17 AM
Going back to the Dark Side!
with the longer arm set at full soft, you are probably at the same spring rate as the stock bar (IMG:style_emoticons/default/biggrin.gif)
Looks good Rob....those are nice looking bars that GPR puts out.
tradisrad
post Nov 9 2010, 09:51 AM
QUOTE(DanT @ Nov 9 2010, 07:17 AM) *
It sure feels better than the stock bar. I am not getting the lifting in the rear on freeway on ramps like I was getting with the stock bar & I am and not getting the flat dive into the corners (with the 22mm bar) nor do I feel any oversteer.
So, how do I know what setting of the bar will give me a true 19mm bar spring rate. I assumed that setting the drop link at the end of the arm it would give me the spring rate of 19mm. What will the spring rate increase to as the drop link moves closer to the bar? Can we make or get a chart to help define the setting?
thanks
-Rob
post Nov 9 2010, 01:26 PM
Resident German
QUOTE(tradisrad @ Nov 9 2010, 07:51 AM) *
I don't think that's what you should be looking for. Trying to set a bar "by numbers" for a initial setup is asking for trouble.
Start with the bar set to full soft tight and tighten soften until you dialed out most (or all) of the understeer.
No two cars will have/need the same settings. You need to forget about numbers and dial in the bar to where your car handles the best according to your personal preference.
Just a word of advice. DO NOT attempt to dial in a bar on public roads. If you overshoot the settings you can end up with severe oversteer which will result in the car switching ends during high speed cornering!!!
Do your setup testing in a large empty parking lot away from anything you can hit. I usually use one of the local AX venues to do some fine tuning. All you can hit there are plastic cones.
EDIT: Modified for correct orientation ...
ChrisFoley
post Nov 9 2010, 08:50 PM
I am Tangerine Racing
QUOTE(SirAndy @ Nov 9 2010, 03:26 PM) *
Start with the bar set to full soft and tighten until you dialed out most (or all) of the understeer.
I think you've got that backwards Andy.
soft front bar = oversteer
My recommendation is to set the bar between 1/3 and halfway in from the end to start with.
post Nov 9 2010, 09:58 PM
Resident German
QUOTE(Racer Chris @ Nov 9 2010, 06:50 PM) *
Baaaah ... Why do i always reverse the two? Go figure ...
Chris is right, it's the other way round ...
If the rear is lose, tighten the front. (IMG:style_emoticons/default/rolleyes.gif)
hwgunner   New GPRBar SWAY BAR Kinda Cool, I Think   Feb 24 2010, 03:17 PM
jcambo7   I want one of these! :driving:   Feb 24 2010, 03:41 PM
markb   Operators are standing by.......... :D   Feb 24 2010, 03:52 PM
jcambo7   Operators are standing by.......... :D Yeah. I ...   Feb 24 2010, 04:00 PM
hwgunner   Operators are standing by.......... :D Yeah. I...   Feb 24 2010, 04:08 PM
jcambo7   [quote name='jcambo7' post='1278441' date='Feb 24...   Feb 24 2010, 04:16 PM
aircooledtechguy   Looks like a really nice product (as with all Tare...   Feb 24 2010, 04:13 PM
hwgunner   Looks like a really nice product (as with all Tar...   Feb 24 2010, 04:30 PM
SirAndy   This is a complete sway bar set up. A suggestion ...   Feb 24 2010, 04:14 PM
hwgunner   This is a complete sway bar set up. A suggestion...   Feb 24 2010, 05:09 PM
SirAndy   I will see what i can do about this. Great idea....   Feb 24 2010, 05:15 PM
jcambo7   :agree: This would definitely help out a lot that...   Feb 24 2010, 07:51 PM
McMark   :headbanger:   Feb 24 2010, 08:47 PM
dr914@autoatlanta.com   Dave was always quite the innovator and it looks l...   Feb 24 2010, 09:01 PM
hwgunner   Dave was always quite the innovator and it looks ...   Feb 24 2010, 11:23 PM
Eric_Shea   I heard about this from Ira... great idea. Andy...   Feb 24 2010, 09:01 PM
6freak   splines on the end of the sway bar it self would b...   Feb 25 2010, 11:27 AM
hwgunner   splines on the end of the sway bar it self would ...   Feb 25 2010, 01:53 PM
Dave_Darling   Aaahndy, you can make a lot of markings with a ...   Feb 25 2010, 02:50 PM
SirAndy   Aaahndy, you can make a lot of markings with a ...   Feb 25 2010, 02:54 PM
rdauenhauer   Jonathan so the round retaining elements are Beari...   Feb 25 2010, 06:11 PM
hwgunner   Jonathan so the round retaining elements are Bear...   Feb 26 2010, 11:36 AM
siverson   > I have a very early Tarett bar and otherwise ...   Feb 25 2010, 08:23 PM
SirAndy   Let me know if I'm wrong though... You are co...   Feb 25 2010, 09:43 PM
Chris Hamilton   So the $475 GPR bar is just the bar and bushi...   Feb 25 2010, 10:00 PM
hwgunner   So the $475 GPR bar is just the bar and bush...   Feb 26 2010, 09:39 AM
sww914   I have one of these at my shop right now and it is...   Feb 25 2010, 10:02 PM
sean_v8_914   markings, YES! we have a Tarret bar on the 10j...   Feb 26 2010, 08:56 AM
Phoenix 914-6GT   Nice Jonathan :headbanger: Still have my big Tar...   Feb 26 2010, 11:27 AM
mtn flyr   Are these in stock at this time?   Feb 26 2010, 01:59 PM
hwgunner   Are these in stock at this time? Yes they are i...   Feb 26 2010, 02:01 PM
BigD9146gt   New GPRBar SWAY BAR Kinda Cool, I Think WAY TO G...   Feb 26 2010, 02:14 PM
mtn flyr   I'll be in touch soon, and here is a :bump: ...   Feb 27 2010, 08:35 PM
campbellcj   If somebody made a REAR 914 swaybar with better qu...   Feb 28 2010, 10:58 AM
markb   :bump: I spent all day putting together the kits f...   Mar 3 2010, 07:15 PM
nsr-jamie   Hi, I know this is an older thread, I am very inte...   Nov 6 2010, 02:41 AM
tradisrad   I got my GPRBar in the mail today and it looks gre...   Nov 8 2010, 04:30 PM
hwgunner   I got my GPRBar in the mail today and it looks gr...   Nov 8 2010, 05:33 PM
RobW   I picked the one up that was in the classifieds......   Nov 8 2010, 05:56 PM
tradisrad   I picked the one up that was in the classifieds.....   Nov 8 2010, 05:59 PM
RobW   I picked the one up that was in the classifieds....   Nov 8 2010, 06:19 PM
NC_Colfax   Looks like a very well made product   Nov 8 2010, 05:57 PM
Eric_Shea   Sounds like you're doing the right thing. :tro...   Nov 8 2010, 06:01 PM
SirAndy   If you get the arms with it, set them full soft an...   Nov 8 2010, 06:10 PM
tradisrad   The New GPRBar is installed. I took it for a short...   Nov 9 2010, 08:55 AM
DanT   with the longer arm set at full soft, you are prob...   Nov 9 2010, 09:17 AM
tradisrad   with the longer arm set at full soft, you are pro...   Nov 9 2010, 09:51 AM
SirAndy   So, how do I know what setting of the bar will giv...   Nov 9 2010, 01:26 PM
Racer Chris   Start with the bar set to full soft and tighten u...   Nov 9 2010, 08:50 PM
SirAndy   I think you've got that backwards Andy. soft f...   Nov 9 2010, 09:58 PM
Eric_Shea   Just for the fun of it... I'm going to :agr...   Nov 9 2010, 09:52 AM
- Lo-Fi Version Time is now: 24th June 2026 - 02:08 PM
