| realred914 |
Nov 13 2010, 08:08 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
| Jake Raby |
Nov 15 2010, 01:03 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE so what I gather is offered by raby is a new bus head modified to replicate the 2 liter 914 head with smaller diameter spark plug threads but same chamber and ports. and same valve sizes. does this seem right? Partially. The smaller plugs make for stronger chambers more resistant to cracking. QUOTE So it appears I can fix my heads to be more or less the same not sure if i will change the plug hole or not. But you'll be making a significant investment in a set of castings that are still 35+ years old and are on their ninth life. I believe in spending more money initially but ending up with a component thats fresh and still on its first life, seems like money better spent to me. thats the reason why ALL my new engines and kits use these same cylinder heads. QUOTE so the stock valves work with the raby cam (still have no idea which cam to choose, several are offered) I work it differently.. You supply me with the specs of the engine, your RPM range and a ton more info and I select the cam from my library. Here we do not use the "one line description" for camshafts because no one understands these cams better than I do, since I developed each of them and have used them in complete engines so I know their characteristics when coupled to various combinations.. You might be better off going with Elgin, they let you pick exactly what you want. The only problem with that is most people have no idea what they really need. There is a very good reason why so many people have told you to buy my cam kit. |
| realred914 |
Nov 15 2010, 04:44 PM
QUOTE so what I gather is offered by raby is a new bus head modified to replicate the 2 liter 914 head with smaller diameter spark plug threads but same chamber and ports. and same valve sizes. does this seem right? Partially. The smaller plugs make for stronger chambers more resistant to cracking. QUOTE So it appears I can fix my heads to be more or less the same not sure if i will change the plug hole or not. But you'll be making a significant investment in a set of castings that are still 35+ years old and are on their ninth life. I believe in spending more money initially but ending up with a component thats fresh and still on its first life, seems like money better spent to me. thats the reason why ALL my new engines and kits use these same cylinder heads. QUOTE so the stock valves work with the raby cam (still have no idea which cam to choose, several are offered) I work it differently.. You supply me with the specs of the engine, your RPM range and a ton more info and I select the cam from my library. Here we do not use the "one line description" for camshafts because no one understands these cams better than I do, since I developed each of them and have used them in complete engines so I know their characteristics when coupled to various combinations.. You might be better off going with Elgin, they let you pick exactly what you want. The only problem with that is most people have no idea what they really need. There is a very good reason why so many people have told you to buy my cam kit. i will get you the engine specs once i get the data from others results, compression changes for example also depends on the cam cgoice, so my static compression ratio plus the cam choice and some other factors help determine the actual dynamic compression ratio., got to select them togther both teh camand the compression , I dont want to pick a compression that may get a cam that compromises something else maybe??? open to any discusion on pros- and cons of the varius combonations with a D-jet compatble engine as the constraint.????????????? |
realred914 what have you done with stock FI and performance mods? Nov 13 2010, 08:08 PM
rdauenhauer check out the eng. FS in my signature :wavebye: . Nov 13 2010, 08:17 PM
Bleyseng My recommendation is
Raby cam and lifters-(9950 or... Nov 14 2010, 09:20 AM
realred914
Raby cam and lifters-(9950 o... Nov 14 2010, 10:58 AM
Jake Raby
[quote name='Bleyseng' post='1394327' date='Nov 1... Nov 14 2010, 08:57 PM
realred914
[quote name='Bleyseng' post='1394327' date='Nov ... Nov 15 2010, 10:18 AM
Bleyseng Look at this for head info on the LE180 -http://ww... Nov 15 2010, 11:31 AM
realred914
Look at this for head info on the LE180 -http://w... Nov 15 2010, 12:00 PM
Root_Werks Loose the D-Jet! :D Nov 15 2010, 12:10 PM
realred914
Loose the D-Jet! :D
sorry not an option f... Nov 15 2010, 12:31 PM
tradisrad I am happy with Jakes cam, but I got one w/o the p... Nov 15 2010, 01:06 PM
Cap'n Krusty Over the last 37 (almost 38!) years I've u... Nov 15 2010, 05:58 PM
Jake Raby
Over the last 37 (almost 38!) years I've ... Nov 15 2010, 06:59 PM
rdauenhauer
I do understand that I can send my MPS to Bleysen... Nov 15 2010, 06:04 PM
Root_Werks
I do understand that I can send my MPS to Bleyse... Nov 16 2010, 02:56 PM
TargaToy For you guys with experience, what kind of power c... Nov 15 2010, 09:23 PM
Jake Raby
For you guys with experience, what kind of power ... Nov 15 2010, 09:37 PM
roadster fan
Is there no hope to make 120-130 hp with a tuned ... Nov 22 2010, 03:08 PM
Bleyseng
Is there no hope to make 120-130 hp with a tuned... Nov 23 2010, 10:14 AM
TargaToy That's good stuff, Jake.
How about with a 191... Nov 15 2010, 09:44 PM
draganc @realred914, what is your budget?
you know that ... Nov 15 2010, 10:22 PM
vsg914 :bump:
you kn... Nov 16 2010, 06:09 AM
you know that ... Nov 16 2010, 07:55 PM
tradisrad
you know that... Nov 16 2010, 08:31 AM
realred914
you know that... Nov 16 2010, 01:01 PM
Jake Raby To those who are seriously dedicated its about muc... Nov 16 2010, 07:49 AM
Jake Raby And the 914 is still more of a budget minded vehic... Nov 16 2010, 08:12 PM
realred914 my engien should be near 2 grand parts and labour.... Nov 17 2010, 10:16 AM
vsg914 Draganc, 2500 bucks includes everything, including... Nov 17 2010, 10:51 AM
tradisrad
Draganc, 2500 bucks includes everything, includin... Nov 17 2010, 11:15 AM
draganc
Draganc, 2500 bucks includes everything, includin... Nov 18 2010, 09:01 PM
vsg914 J[quote name='draganc' date='Nov 18 20... Nov 19 2010, 06:18 AM
Cap'n Krusty Considering the fact that 914 cylinder head recond... Nov 17 2010, 01:37 PM
Bleyseng
Considering the fact that 914 cylinder head recon... Nov 18 2010, 04:50 AM
john rogers There is a shop in the Venice Beach area, I think,... Nov 17 2010, 04:00 PM
Root_Werks
There is a shop in the Venice Beach area, I think... Nov 17 2010, 04:47 PM
realred914
There is a shop in the Venice Beach area, I thin... Nov 18 2010, 12:11 PM
stugray vsg914,
"Will i tell you where i get them? S... Nov 17 2010, 05:18 PM
vsg914 Stu,if i share my source with the world, i would n... Nov 18 2010, 06:41 AM
realred914 If folks wont share data, please post elsewhere, s... Nov 18 2010, 12:19 PM
rdauenhauer Im confused, you ask for detailed information yet ... Nov 18 2010, 04:00 PM
realred914
Im confused, you ask for detailed information yet... Nov 18 2010, 04:30 PM
HAM Inc Here's the info you need for the internals fro... Nov 18 2010, 04:38 PM
realred914
Here's the info you need for the internals fr... Nov 18 2010, 06:24 PM
realred914 ps my under standing of the 911 swivil feet is tha... Nov 18 2010, 06:28 PM
HAM Inc
The 911 swivel screws eliminate the friction loa... Nov 19 2010, 09:09 AM
realred914
The 911 swivel screws eliminate the friction lo... Nov 19 2010, 12:26 PM
Bleyseng Good luck finding out that data as a few years ago... Nov 20 2010, 05:30 AM
HAM Inc
I understand the desire to scrutinize the cam sp... Nov 20 2010, 10:27 AM
realred914
I understand the desire to scrutinze the cam sp... Nov 20 2010, 10:35 AM
Jake Raby
I understand the desire to scrutinze the cam s... Nov 22 2010, 08:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:38 PM |
