| realred914 |
Nov 13 2010, 08:08 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
| Cap'n Krusty |
Nov 15 2010, 05:58 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Over the last 37 (almost 38!) years I've used a number of camshafts that were advertised as D-jet compatible. None were. (I've not tried Jake's, but I respect his knowledge and the hands on practical research he's done to ensure his WILL work as advertised.) Many (most?) of the others have been designed by engineers who haven't used them in an emissions controlled environment, nor do they appear to have had any practical experience in driveability. The system expects to see a certain set of vacuum characteristics that come from the stock camshaft profile, and few, if any, offerings of the big names in camshaft grinding provide those characteristics. Web Cam doesn't, Norris didn't, Isky, the same, nor any of the others I've tried. They all run really fat at idle, have a flat spot you could play pool on, and are otherwise a PITA to tune and to drive.
Consider that, please, before you pick a cam. They're a REAL PITA to replace once you've decided I might just be right. The Cap'n |
| Jake Raby |
Nov 15 2010, 06:59 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Over the last 37 (almost 38!) years I've used a number of camshafts that were advertised as D-jet compatible. None were. (I've not tried Jake's, but I respect his knowledge and the hands on practical research he's done to ensure his WILL work as advertised.) Many (most?) of the others have been designed by engineers who haven't used them in an emissions controlled environment, nor do they appear to have had any practical experience in driveability. The system expects to see a certain set of vacuum characteristics that come from the stock camshaft profile, and few, if any, offerings of the big names in camshaft grinding provide those characteristics. Web Cam doesn't, Norris didn't, Isky, the same, nor any of the others I've tried. They all run really fat at idle, have a flat spot you could play pool on, and are otherwise a PITA to tune and to drive. Consider that, please, before you pick a cam. They're a REAL PITA to replace once you've decided I might just be right. The Cap'n I agree with The Cap'n... I tried all the off the shelf offerings with no success until I developed the 9550, 9560 and 9590 grinds back in 1999. They were all developed to have a very conservative opening event to enhance the vaccum signature that the MPS sees. This is VERY critical to proper operation. I tried over ten variations of the first version which is based from the Web 73 grind, the lobe separation and exhaust profile are altered from that base grind. I've sold about 1500 of these camshafts, about 60 of those were sold this year. Out of all those I've had two complaints, both from people who misconfigured the remainder of their engine around the 9550 camshaft. Thats the reason why I am so critical of the combination that my camshaft will be used in conjunction with. Cam grinders aren't engine builders, they have no idea how their product couples to different head configurations, induction systems or exhaust systems. I tell the cam grinder what to grind, I don't ask them to recommend what I need. They are about the worst person to make the selection. I wonder how many of them drove a TIV powered car to work today? |
realred914 what have you done with stock FI and performance mods? Nov 13 2010, 08:08 PM
rdauenhauer check out the eng. FS in my signature :wavebye: . Nov 13 2010, 08:17 PM
Bleyseng My recommendation is
Raby cam and lifters-(9950 or... Nov 14 2010, 09:20 AM
realred914
Raby cam and lifters-(9950 o... Nov 14 2010, 10:58 AM
Jake Raby
[quote name='Bleyseng' post='1394327' date='Nov 1... Nov 14 2010, 08:57 PM
realred914
[quote name='Bleyseng' post='1394327' date='Nov ... Nov 15 2010, 10:18 AM
Bleyseng Look at this for head info on the LE180 -http://ww... Nov 15 2010, 11:31 AM
realred914
Look at this for head info on the LE180 -http://w... Nov 15 2010, 12:00 PM
Root_Werks Loose the D-Jet! :D Nov 15 2010, 12:10 PM
realred914
Loose the D-Jet! :D
sorry not an option f... Nov 15 2010, 12:31 PM
Jake Raby
Partially. The smaller plugs make for stronger c... Nov 15 2010, 01:03 PM
realred914
Partially. The smaller plugs make for stronger ... Nov 15 2010, 04:44 PM
tradisrad I am happy with Jakes cam, but I got one w/o the p... Nov 15 2010, 01:06 PM
rdauenhauer
I do understand that I can send my MPS to Bleysen... Nov 15 2010, 06:04 PM
Root_Werks
I do understand that I can send my MPS to Bleyse... Nov 16 2010, 02:56 PM
TargaToy For you guys with experience, what kind of power c... Nov 15 2010, 09:23 PM
Jake Raby
For you guys with experience, what kind of power ... Nov 15 2010, 09:37 PM
roadster fan
Is there no hope to make 120-130 hp with a tuned ... Nov 22 2010, 03:08 PM
Bleyseng
Is there no hope to make 120-130 hp with a tuned... Nov 23 2010, 10:14 AM
TargaToy That's good stuff, Jake.
How about with a 191... Nov 15 2010, 09:44 PM
draganc @realred914, what is your budget?
you know that ... Nov 15 2010, 10:22 PM
vsg914 :bump:
you kn... Nov 16 2010, 06:09 AM
you know that ... Nov 16 2010, 07:55 PM
tradisrad
you know that... Nov 16 2010, 08:31 AM
realred914
you know that... Nov 16 2010, 01:01 PM
Jake Raby To those who are seriously dedicated its about muc... Nov 16 2010, 07:49 AM
Jake Raby And the 914 is still more of a budget minded vehic... Nov 16 2010, 08:12 PM
realred914 my engien should be near 2 grand parts and labour.... Nov 17 2010, 10:16 AM
vsg914 Draganc, 2500 bucks includes everything, including... Nov 17 2010, 10:51 AM
tradisrad
Draganc, 2500 bucks includes everything, includin... Nov 17 2010, 11:15 AM
draganc
Draganc, 2500 bucks includes everything, includin... Nov 18 2010, 09:01 PM
vsg914 J[quote name='draganc' date='Nov 18 20... Nov 19 2010, 06:18 AM
Cap'n Krusty Considering the fact that 914 cylinder head recond... Nov 17 2010, 01:37 PM
Bleyseng
Considering the fact that 914 cylinder head recon... Nov 18 2010, 04:50 AM
john rogers There is a shop in the Venice Beach area, I think,... Nov 17 2010, 04:00 PM
Root_Werks
There is a shop in the Venice Beach area, I think... Nov 17 2010, 04:47 PM
realred914
There is a shop in the Venice Beach area, I thin... Nov 18 2010, 12:11 PM
stugray vsg914,
"Will i tell you where i get them? S... Nov 17 2010, 05:18 PM
vsg914 Stu,if i share my source with the world, i would n... Nov 18 2010, 06:41 AM
realred914 If folks wont share data, please post elsewhere, s... Nov 18 2010, 12:19 PM
rdauenhauer Im confused, you ask for detailed information yet ... Nov 18 2010, 04:00 PM
realred914
Im confused, you ask for detailed information yet... Nov 18 2010, 04:30 PM
HAM Inc Here's the info you need for the internals fro... Nov 18 2010, 04:38 PM
realred914
Here's the info you need for the internals fr... Nov 18 2010, 06:24 PM
realred914 ps my under standing of the 911 swivil feet is tha... Nov 18 2010, 06:28 PM
HAM Inc
The 911 swivel screws eliminate the friction loa... Nov 19 2010, 09:09 AM
realred914
The 911 swivel screws eliminate the friction lo... Nov 19 2010, 12:26 PM
Bleyseng Good luck finding out that data as a few years ago... Nov 20 2010, 05:30 AM
HAM Inc
I understand the desire to scrutinize the cam sp... Nov 20 2010, 10:27 AM
realred914
I understand the desire to scrutinze the cam sp... Nov 20 2010, 10:35 AM
Jake Raby
I understand the desire to scrutinze the cam s... Nov 22 2010, 08:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:39 PM |
