| championgt1 |
Nov 15 2010, 02:43 PM
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,683 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Installed a new battery and started the car. Voltmeter gauge reads around 13 volts. Cool. Turn the headlights on, gauge reads about 12. Cool. Hit the brake pedal gauge now drops below 11. Not cool.
The owners manual says the gauge should stay between 12 and 14 with loads applied. Mine is dropping below 11. Any ideas? Bad Ground? |
| Spoke |
Nov 15 2010, 08:57 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,427 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Ohms law says it all: V = I x R
With current (I) and resistance ®, a voltage drop (V) happens. When this voltage drop happens to and from the intended load (head lights, turn signals, fuel pump, etc), your load sees less voltage than at the battery. The wiring is resistive ®, the old, oxidized spade connectors on the fuse panel are resistive ®, every ground and power lug connection can get oxidized and act resistive ®. You can't do much about the wiring but you can clean all the ground and power connectors. This will help minimize the voltage drops but will not eliminate them. You can also get a layer of oxidation between the battery terminal and its connector. I had trouble starting my car, checked the battery connectors and they were tight. When the car wouldn't start, I turned the headlights on and measured about 8V drop between the battery positive terminal and its connector. Cleaned that one off and never had trouble starting after that. |
championgt1 Voltmeter gauge drops under 11 volts Nov 15 2010, 02:43 PM
r_towle check with a digital volt meter at the battery.
Se... Nov 15 2010, 02:46 PM
dr914@autoatlanta.com totally normal (as stated in the Tech Tips 700) th... Nov 15 2010, 03:32 PM
championgt1 Checked voltage at the battery with a meter. Gauge... Nov 15 2010, 05:57 PM
cary Mine does the same thing. I was thinking I needed ... Nov 15 2010, 09:10 PM
jim_hoyland I went through the same thing. Finally wired the b... Nov 15 2010, 09:10 PM
jk76.914
I went through the same thing. Finally wired the ... Nov 16 2010, 04:25 AM
cary Finally got around rewiring the voltage gauge.
Rel... Sep 5 2012, 08:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 05:23 PM |
