| realred914 |
Nov 13 2010, 08:08 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
| draganc |
Nov 15 2010, 10:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
@realred914, what is your budget?
you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". |
| TheCabinetmaker |
Nov 16 2010, 06:09 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
(IMG:style_emoticons/default/icon_bump.gif) [quote name='draganc' date='Nov 15 2010, 10:22 PM' post='1395030']
@realred914, what is your budget? you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". [I/quote] G[quote name='draganc' date='Nov 15 2010, 10:22 PM' post='1395030'] @realred914, what is your budget? you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". [/quote] I disagree! I have all my parts and have started the build with jakes cam set and have less than $2500 invested |
realred914 what have you done with stock FI and performance mods? Nov 13 2010, 08:08 PM
rdauenhauer check out the eng. FS in my signature :wavebye: . Nov 13 2010, 08:17 PM
Bleyseng My recommendation is
Raby cam and lifters-(9950 or... Nov 14 2010, 09:20 AM
realred914
Raby cam and lifters-(9950 o... Nov 14 2010, 10:58 AM
Jake Raby
[quote name='Bleyseng' post='1394327' date='Nov 1... Nov 14 2010, 08:57 PM
realred914
[quote name='Bleyseng' post='1394327' date='Nov ... Nov 15 2010, 10:18 AM
Bleyseng Look at this for head info on the LE180 -http://ww... Nov 15 2010, 11:31 AM
realred914
Look at this for head info on the LE180 -http://w... Nov 15 2010, 12:00 PM
Root_Werks Loose the D-Jet! :D Nov 15 2010, 12:10 PM
realred914
Loose the D-Jet! :D
sorry not an option f... Nov 15 2010, 12:31 PM
Jake Raby
Partially. The smaller plugs make for stronger c... Nov 15 2010, 01:03 PM
realred914
Partially. The smaller plugs make for stronger ... Nov 15 2010, 04:44 PM
tradisrad I am happy with Jakes cam, but I got one w/o the p... Nov 15 2010, 01:06 PM
Cap'n Krusty Over the last 37 (almost 38!) years I've u... Nov 15 2010, 05:58 PM
Jake Raby
Over the last 37 (almost 38!) years I've ... Nov 15 2010, 06:59 PM
rdauenhauer
I do understand that I can send my MPS to Bleysen... Nov 15 2010, 06:04 PM
Root_Werks
I do understand that I can send my MPS to Bleyse... Nov 16 2010, 02:56 PM
TargaToy For you guys with experience, what kind of power c... Nov 15 2010, 09:23 PM
Jake Raby
For you guys with experience, what kind of power ... Nov 15 2010, 09:37 PM
roadster fan
Is there no hope to make 120-130 hp with a tuned ... Nov 22 2010, 03:08 PM
Bleyseng
Is there no hope to make 120-130 hp with a tuned... Nov 23 2010, 10:14 AM
TargaToy That's good stuff, Jake.
How about with a 191... Nov 15 2010, 09:44 PM
draganc @realred914, what is your budget?
you know that ... Nov 16 2010, 07:55 PM
tradisrad
you know that... Nov 16 2010, 08:31 AM
realred914
you know that... Nov 16 2010, 01:01 PM
Jake Raby To those who are seriously dedicated its about muc... Nov 16 2010, 07:49 AM
Jake Raby And the 914 is still more of a budget minded vehic... Nov 16 2010, 08:12 PM
realred914 my engien should be near 2 grand parts and labour.... Nov 17 2010, 10:16 AM
vsg914 Draganc, 2500 bucks includes everything, including... Nov 17 2010, 10:51 AM
tradisrad
Draganc, 2500 bucks includes everything, includin... Nov 17 2010, 11:15 AM
draganc
Draganc, 2500 bucks includes everything, includin... Nov 18 2010, 09:01 PM
vsg914 J[quote name='draganc' date='Nov 18 20... Nov 19 2010, 06:18 AM
Cap'n Krusty Considering the fact that 914 cylinder head recond... Nov 17 2010, 01:37 PM
Bleyseng
Considering the fact that 914 cylinder head recon... Nov 18 2010, 04:50 AM
john rogers There is a shop in the Venice Beach area, I think,... Nov 17 2010, 04:00 PM
Root_Werks
There is a shop in the Venice Beach area, I think... Nov 17 2010, 04:47 PM
realred914
There is a shop in the Venice Beach area, I thin... Nov 18 2010, 12:11 PM
stugray vsg914,
"Will i tell you where i get them? S... Nov 17 2010, 05:18 PM
vsg914 Stu,if i share my source with the world, i would n... Nov 18 2010, 06:41 AM
realred914 If folks wont share data, please post elsewhere, s... Nov 18 2010, 12:19 PM
rdauenhauer Im confused, you ask for detailed information yet ... Nov 18 2010, 04:00 PM
realred914
Im confused, you ask for detailed information yet... Nov 18 2010, 04:30 PM
HAM Inc Here's the info you need for the internals fro... Nov 18 2010, 04:38 PM
realred914
Here's the info you need for the internals fr... Nov 18 2010, 06:24 PM
realred914 ps my under standing of the 911 swivil feet is tha... Nov 18 2010, 06:28 PM
HAM Inc
The 911 swivel screws eliminate the friction loa... Nov 19 2010, 09:09 AM
realred914
The 911 swivel screws eliminate the friction lo... Nov 19 2010, 12:26 PM
Bleyseng Good luck finding out that data as a few years ago... Nov 20 2010, 05:30 AM
HAM Inc
I understand the desire to scrutinize the cam sp... Nov 20 2010, 10:27 AM
realred914
I understand the desire to scrutinze the cam sp... Nov 20 2010, 10:35 AM
Jake Raby
I understand the desire to scrutinze the cam s... Nov 22 2010, 08:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 04:38 PM |
