> what have you done with stock FI and performance mods?, quest for a killer D-jet 2056cc motor
realred914
post Nov 13 2010, 08:08 PM
Group: Retired Members
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc....
will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat.
what can be done during rebuild to beef up the power????
draganc
post Nov 15 2010, 10:22 PM
@realred914, what is your budget?
you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp.
if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade".
TheCabinetmaker
post Nov 16 2010, 06:09 AM
I drive my car everyday
(IMG:style_emoticons/default/icon_bump.gif) [quote name='draganc' date='Nov 15 2010, 10:22 PM' post='1395030']
[I/quote]
G[quote name='draganc' date='Nov 15 2010, 10:22 PM' post='1395030']
[/quote]
I disagree! I have all my parts and have started the build with jakes cam set and have less than $2500 invested
draganc
post Nov 16 2010, 07:55 PM
[/quote]
[/quote]
@vsg914, can you list the parts that you have bought for $2500? How about new heads or head work? Balancing?
I have about the same amount invested in parts, plus balancing and ceramic coating. main bearings only are about $150 a set. Then you need/should refurb the old injectors, that's about $120 a set.
It's difficult for me to believe that a T4 overhaul is only $2500.
If you can do it please share your secrets. I would very much appreciate your input.
@ Jake, I’m sure that a lot of fellow club members are seriously dedicated to their 914, however, the budget is the budget. Unfortunately not everybody is able to spend $10k on a engine build.
I know you don’t cut corners and that’s good and is very well reflected in your great engine kits, however, the 914 was introduced to the market as a budget alternative to the 911.
realred914   what have you done with stock FI and performance mods?   Nov 13 2010, 08:08 PM
rdauenhauer   check out the eng. FS in my signature :wavebye: .   Nov 13 2010, 08:17 PM
Bleyseng   My recommendation is Raby cam and lifters-(9950 or...   Nov 14 2010, 09:20 AM
realred914   My recommendation is Raby cam and lifters-(9950 o...   Nov 14 2010, 10:58 AM
Jake Raby   [quote name='Bleyseng' post='1394327' date='Nov 1...   Nov 14 2010, 08:57 PM
realred914   [quote name='Bleyseng' post='1394327' date='Nov ...   Nov 15 2010, 10:18 AM
Bleyseng   Look at this for head info on the LE180 -http://ww...   Nov 15 2010, 11:31 AM
realred914   Look at this for head info on the LE180 -http://w...   Nov 15 2010, 12:00 PM
Root_Werks   Loose the D-Jet! :D   Nov 15 2010, 12:10 PM
realred914   Loose the D-Jet! :D sorry not an option f...   Nov 15 2010, 12:31 PM
Jake Raby   Partially. The smaller plugs make for stronger c...   Nov 15 2010, 01:03 PM
realred914   Partially. The smaller plugs make for stronger ...   Nov 15 2010, 04:44 PM
tradisrad   I am happy with Jakes cam, but I got one w/o the p...   Nov 15 2010, 01:06 PM
Cap'n Krusty   Over the last 37 (almost 38!) years I've u...   Nov 15 2010, 05:58 PM
Jake Raby   Over the last 37 (almost 38!) years I've ...   Nov 15 2010, 06:59 PM
rdauenhauer   I do understand that I can send my MPS to Bleysen...   Nov 15 2010, 06:04 PM
Root_Werks   I do understand that I can send my MPS to Bleyse...   Nov 16 2010, 02:56 PM
TargaToy   For you guys with experience, what kind of power c...   Nov 15 2010, 09:23 PM
Jake Raby   For you guys with experience, what kind of power ...   Nov 15 2010, 09:37 PM
roadster fan   Is there no hope to make 120-130 hp with a tuned ...   Nov 22 2010, 03:08 PM
Bleyseng   Is there no hope to make 120-130 hp with a tuned...   Nov 23 2010, 10:14 AM
TargaToy   That's good stuff, Jake. How about with a 191...   Nov 15 2010, 09:44 PM
draganc   @realred914, what is your budget? you know that ...   Nov 15 2010, 10:22 PM
vsg914   :bump: @realred914, what is your budget? you kn...   Nov 16 2010, 06:09 AM
draganc   @realred914, what is your budget? you know that ...   Nov 16 2010, 07:55 PM
tradisrad   @realred914, what is your budget? you know that...   Nov 16 2010, 08:31 AM
realred914   @realred914, what is your budget? you know that...   Nov 16 2010, 01:01 PM
Jake Raby   To those who are seriously dedicated its about muc...   Nov 16 2010, 07:49 AM
Jake Raby   And the 914 is still more of a budget minded vehic...   Nov 16 2010, 08:12 PM
realred914   my engien should be near 2 grand parts and labour....   Nov 17 2010, 10:16 AM
vsg914   Draganc, 2500 bucks includes everything, including...   Nov 17 2010, 10:51 AM
tradisrad   Draganc, 2500 bucks includes everything, includin...   Nov 17 2010, 11:15 AM
draganc   Draganc, 2500 bucks includes everything, includin...   Nov 18 2010, 09:01 PM
vsg914   J[quote name='draganc' date='Nov 18 20...   Nov 19 2010, 06:18 AM
Cap'n Krusty   Considering the fact that 914 cylinder head recond...   Nov 17 2010, 01:37 PM
Bleyseng   Considering the fact that 914 cylinder head recon...   Nov 18 2010, 04:50 AM
john rogers   There is a shop in the Venice Beach area, I think,...   Nov 17 2010, 04:00 PM
Root_Werks   There is a shop in the Venice Beach area, I think...   Nov 17 2010, 04:47 PM
realred914   There is a shop in the Venice Beach area, I thin...   Nov 18 2010, 12:11 PM
stugray   vsg914, "Will i tell you where i get them? S...   Nov 17 2010, 05:18 PM
vsg914   Stu,if i share my source with the world, i would n...   Nov 18 2010, 06:41 AM
realred914   If folks wont share data, please post elsewhere, s...   Nov 18 2010, 12:19 PM
rdauenhauer   Im confused, you ask for detailed information yet ...   Nov 18 2010, 04:00 PM
realred914   Im confused, you ask for detailed information yet...   Nov 18 2010, 04:30 PM
HAM Inc   Here's the info you need for the internals fro...   Nov 18 2010, 04:38 PM
realred914   Here's the info you need for the internals fr...   Nov 18 2010, 06:24 PM
realred914   ps my under standing of the 911 swivil feet is tha...   Nov 18 2010, 06:28 PM
HAM Inc   The 911 swivel screws eliminate the friction loa...   Nov 19 2010, 09:09 AM
realred914   The 911 swivel screws eliminate the friction lo...   Nov 19 2010, 12:26 PM
Bleyseng   Good luck finding out that data as a few years ago...   Nov 20 2010, 05:30 AM
HAM Inc   I understand the desire to scrutinize the cam sp...   Nov 20 2010, 10:27 AM
realred914   I understand the desire to scrutinze the cam sp...   Nov 20 2010, 10:35 AM
Jake Raby   I understand the desire to scrutinze the cam s...   Nov 22 2010, 08:10 PM
- Lo-Fi Version Time is now: 9th June 2026 - 04:37 PM
