> 914 won't start, 914 starting problems...
tpines
post Nov 22 2010, 01:32 PM
Hi Guys,
I have a '74 2.0 that has original FI and runs very well. However, after a hour drive or so, the car will not start for about 10 minutes or until it cools down. I have replaced the starter and voltage regulator but still the same problem persists. I have heard of relocating the fuel pump to the front in order to prevent vapor lock but have not tried this yet. Any advice would be greatly appreciated...
Clark.
Root_Werks
post Nov 22 2010, 02:05 PM
Village Idiot
Of the........35+ 914's I've owned, never needed a hot start kit.
Check your grounds, replace the ignition switch, check terminal connections from source to end for starter.
You should be fine.
post Nov 22 2010, 02:19 PM
Resident German
QUOTE(Root_Werks @ Nov 22 2010, 12:05 PM) *
While i can certainly see the benefit of adding a relay to the starter circuit, the hot start kit is a band-aid, not a solution for your problem.
Find the problem and fix it. Then think about adding a relay to the starter ...
- Lo-Fi Version Time is now: 4th July 2025 - 06:39 AM
