| HAM Inc |
Nov 22 2010, 01:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
![]() ![]() Another thread got me thinking about a customer I had some time ago with a 2.0 He thought he was driving around with an exhaust leak. Much effort was put into fixing the problem before it dawned on him that this was more than an exhaust leak. A perfect example of why we hate head gaskets on these engines! This head was toast and went to the scrap pile! And it is another example of the need to do a compression test the minute you develop an exhaust leak. Even if you don't have head gaskets! |
| Jake Raby |
Nov 23 2010, 10:38 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
A gasket thats not there, can't fail.. This failure occurs much more frequently with engines that retain the head gaskets..
Hence the VW Bulletin to omit them released in the 80s. |
| Cap'n Krusty |
Nov 23 2010, 08:11 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
A gasket thats not there, can't fail.. This failure occurs much more frequently with engines that retain the head gaskets.. Hence the VW Bulletin to omit them released in the 80s. Come on, Jake. Sure there's a bulletin, but (IIRC) it goes with the head redesign, and it refers only to VW T2s. Leaving that part out diminishes the point you're trying to make. Not that I think your point is wrong .............. The Cap'n |
HAM Inc Misdiagnosed exhaust leak Nov 22 2010, 01:32 PM
jsayre914 :barf:
OMG that dosnt look good. What happend to... Nov 22 2010, 05:54 PM
bandjoey That's Terminal! Was there a loud leak or... Nov 22 2010, 05:59 PM
Jake Raby Fellas, thats typical damage from a blown head gas... Nov 22 2010, 07:50 PM
charliew I've seen cast iron blocks cut between the cyl... Nov 22 2010, 11:03 PM
HAM Inc
That was an example of a failure that did not ha... Nov 23 2010, 08:49 AM
Cap'n Krusty Head gasket or no head gasket, the REAL reason the... Nov 23 2010, 09:48 AM
Jake Raby
A gasket thats not there, can't fail.. This ... Nov 23 2010, 09:30 PM
Brett W You can already see the questionable ability of th... Nov 23 2010, 10:42 AM
Drums66
You can already see the questionable ability of t... Nov 23 2010, 06:09 PM
HAM Inc
Amen! It's remarkable how many ignored w... Nov 23 2010, 10:44 AM
Mark Henry I had a head gasket go on an engine I built from u... Nov 23 2010, 10:53 AM
Jake Raby A poor mans compression test is something EVERY TI... Nov 23 2010, 12:06 PM
7275914911
A poor mans compression test is something EVERY T... Nov 23 2010, 07:56 PM
Mike D. OK, but what about the cyl. to head gasket in earl... Nov 23 2010, 07:45 PM
HAM Inc
What Jake is referring to is developing a keen ... Nov 24 2010, 08:51 AM
Kraftwerk O.P. might be referring to me.
WANT TO BUY 1 G... Nov 24 2010, 11:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:45 PM |
