yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Just an idiot check here... I got Evan's old header on the car and all fixed up. It now clears my tuna can, has leak free collector/slip joints, mounts to the stock trans location, and has an O2 bung welded just past the collector.
Now my question is simple. I wanted to idiot check that I should be gunning for 12.5:1 or so at all points; idle, transition, at WOT. I leaned out on idle to the point that I think I'll need a 65 idle jet on my 40 Dell's (34mm vent). I took an extra full turn on the idle volume screws to get it around 13.5:1. I must say though I picked up more than a few HP with it. It's a 4-1 in somewhat of a KH design with a Phase9 style muffler with an extra 360 degree SS loop between the collector and muffler to add some length to the secondaries. Pictures coming... |
yeahmag |
Put in a 65 idle and it seems OK if not a bit soggy. 12.5-13.0:1 at idle and in transition. I think I'm going a bit rich from transition on to the mains now though...
I'll need to graph it I guess as watching the LM-1 is pointless as it changes too fast. I need to make or buy a cheap gauge that I can dampen the output... |
Lo-Fi Version | Time is now: 10th June 2024 - 07:44 AM |
