O2 readings at idle |
yeahmag |
Nov 29 2010, 08:27 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just an idiot check here... I got Evan's old header on the car and all fixed up. It now clears my tuna can, has leak free collector/slip joints, mounts to the stock trans location, and has an O2 bung welded just past the collector.
Now my question is simple. I wanted to idiot check that I should be gunning for 12.5:1 or so at all points; idle, transition, at WOT. I leaned out on idle to the point that I think I'll need a 65 idle jet on my 40 Dell's (34mm vent). I took an extra full turn on the idle volume screws to get it around 13.5:1. I must say though I picked up more than a few HP with it. It's a 4-1 in somewhat of a KH design with a Phase9 style muffler with an extra 360 degree SS loop between the collector and muffler to add some length to the secondaries. Pictures coming... |
brant |
Dec 1 2010, 01:14 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Idle really doesn't matter
it will hurt your emmisions.. and the motor isn't harmed by a leaner mixture at idle. we often end up at 14:1 or around there (some times even more lean) what matters is the numbers under load and what really matters are the higher rpms. your just hurting your transition and poor tip in performance brant |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:28 AM |
