O2 readings at idle |
yeahmag |
Nov 29 2010, 08:27 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just an idiot check here... I got Evan's old header on the car and all fixed up. It now clears my tuna can, has leak free collector/slip joints, mounts to the stock trans location, and has an O2 bung welded just past the collector.
Now my question is simple. I wanted to idiot check that I should be gunning for 12.5:1 or so at all points; idle, transition, at WOT. I leaned out on idle to the point that I think I'll need a 65 idle jet on my 40 Dell's (34mm vent). I took an extra full turn on the idle volume screws to get it around 13.5:1. I must say though I picked up more than a few HP with it. It's a 4-1 in somewhat of a KH design with a Phase9 style muffler with an extra 360 degree SS loop between the collector and muffler to add some length to the secondaries. Pictures coming... |
yeahmag |
Dec 1 2010, 02:01 PM
I ended up with a 62 idle jet with my stock HE's and a bursch due to a lean part throttle (under load) condition at mid RPM's. With the short tires on a 15" rim I cruise at a fairly high RPM (3500-4000). This produced a lean condition going up hills of the like.
I was (and am) always fine at full throttle. Since I'll put the 62 back in and drive around a bit. Tip in right now seems a bit boggy with the 65. Seemed cleaner with the 62 even though I was showing lean conditions. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:30 AM |
