What upgrades/safety things does a new owner do? |
Super90 |
Dec 3 2010, 11:46 AM
Newbie Group: Members Posts: 13 Joined: 25-November 10 From: GA Member No.: 12,423 Region Association: South East States |
HI all, when my new car gets here I want to go thru it for safety upgrades and eliminate as many roadside breakdown possibilities. It has led a sheltered life, a 2.0. 74 with a lot of great options (less a/c which is ok by me).It has not been driven a lot in the past couple of years.
I was thinking: 1. It has all the original red & green hoses in the engine compartment. Replace all that stuff? 2. Fuel lines replace with SS kit. (who sells?) at same time take out tank & clean it & get new fuel filter. Is there a recommended upgrade filter? 3. Move fuel pump to front. (Could not find a how to type article, any help appreciated) Any recommended upgrade pump? 4. Clutch cable 5. Fan belt 6. Check brake parts & replace/rebuild as necessary. I want to keep the car pretty much stock so not looking for big brake upgrades or such. But should I use a bigger Mastery cylinder like the one on the early 911? Any other recommendations appreciated. I've been reading up on the car via a number of threads here & thru the Haynes shop book. Oh yeah, any other 914 guys/guru's in the Augusta,GA area or in nearby SC or other places reasonably close by? Couldnt figure how to search the memebr list by area. Thanks, George |
Cupomeat |
Dec 3 2010, 12:09 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Ok, My thoughts;
1. It has all the original red & green hoses in the engine compartment. Replace all that stuff? - REPLACE ALL THE FUEL LINES with Ethanol friendly lines 2. Fuel lines replace with SS kit. (who sells?) at same time take out tank & clean it & get new fuel filter. Is there a recommended upgrade filter? - Chris Foley at Tangerine sells them. Others do as well, Check the vendor section here. 3. Move fuel pump to front. (Could not find a how to type article, any help appreciated) Any recommended upgrade pump? - Not immediately needed but a good thing to do! 4. Clutch cable - Good move, not immediately needed. 5. Fan belt - Yes, but not a killer as your car can run without it until the battery dies (the engine fan is directly driven off the crank) 6. Check brake parts & replace/rebuild as necessary. - #1 thing to do. Go through the brakes and replace any original flex lines, bleed the system a few times (you'll need to anyway) and inspect it carefully. I also recommend looking closely at your seat belts to make sure they are in good working condition. Also, replace your wipers as many of us use our cars only in sunny conditions, but if you need them to clear mist kicked off an 18 wheeler while traveling at 85mph on the highway, YOU NEED THEM TO WORK. Good luck! |
Drums66 |
Dec 3 2010, 12:53 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Ok, My thoughts; 6. Check brake parts & replace/rebuild as necessary. - #1 thing to do. Go through the brakes and replace any original flex lines, bleed the system a few times (you'll need to anyway) and inspect it carefully. That's the right 1 ....... (IMG:style_emoticons/default/tunez.gif) (IMG:style_emoticons/default/14.gif) .........popcorn 1 & all |
Lo-Fi Version | Time is now: 8th June 2024 - 10:02 PM |
