| jk76.914 |
Jan 30 2010, 11:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I collected a number of MPS over a couple of years. Most held vacuum, some did not. I measured inductance vs. vacuum on those that I could, but then took all of them apart (except one brand new one).
The is a lot of variety in the diaphrams, probably because they get replaced when virtually every MPS is rebuilt. The photo below shows four diaphrams. I'll follow with descriptions and observations... ![]() #1- copper, 2 pleats. This came from a rebuilt MPS that was in a pond or river for some time. There was actually sand in it, along with tiny aquatic snail shells of some sort, and the copper was pretty much green. This diaphram was ruptured. The workmanship is very good, and the alloy is idential to stock (see chart below). The threaded bushing looks like stock in design and attachment. #2- copper, 3 pleats. This is a stock diaphram from a riveted MPS. It is ruptured. #3- brass, 2 pleats. This is from a rebuilt MPS. I have three of these diaphrams, all similar. This MPS was freshly rebuilt in a rebuilder's box. Looked like new with fresh paint and plastic cap on vacuum port, but it leaked slightly. You can see why when you look at the ripples in that flange. The O.D. looks like it was cut out by hand with tin snips, and the threaded bushing was taken from a stock diaphram and soldered by hand into place. At the bottom in the picture, you can see that the flange is pretty smooth- that's where I tapped it out with a machinist's hammer on an anvil. I have no doubt that the leakage was from around the O.D. of the diaphram, and that tapping it out would probably fix it. This material (brass, see chart below) is stiffer and thicker than any of the rest. It would add quite a bit of spring tension to the mass-spring-damper system. In general, I rate the workmanship on this as "crappy", though maybe you could get a running car out of it. #4- stainless steel, 3 pleats. This one is a bit of an enigma. It is identical to stock except that it is made from stainless (see chart below). The workmanship is perfect. It is from a rebuilt MPS. Interestingly, it is the MOST COMPLIANT of all of them, while most steel ones are reported to be stiffer. The other part of the enigma- the aneroid cells from this MPS are also stainless- same alloy. My suspicion is that this is a late Bosch rebuilt. Who else would make stainless cells, because the cells don't fail very often, so there are lots of spares available out there, and the cells are pretty complicated to make... *** EDITED *** Materials. I measured alloy composition at work using an X-Ray Fluorescence analyzer. This machine is very precise, but it has limits to the range of elements that it can detect. Unfortunately, it cannot detect Beryllium (Be), and it is likely that the stock (at least) diaphram contains Be to harden and strengthen it. You can see a couple of things here though- the stainless diaphram and stainless cells are of exactly the same composition- nickel-chromium stainless steel. The nickel explains why they are slightly magnetic, as many stainless alloys are not. *** ![]() Conclusions (really opinions) - The diaphram was put in there (early VW D-jets did not have one) to provide altitude compensation and to soften transition from leaner (high vacuum) to richer (low vacuum) regions. Early D-Jets had a separate unit with a diaphram and a switch to inform the ECU to richen the mixture at low vacuum. Cost reduction may have been a third reason- eliminating the separate unit, wiring, vacuum hose, etc. Anyway, this switch was either on or off, no soft transition. The MPS had only 2 aneroid cells and no diaphram, and its inductance curve was essentially a straight line from 0" to 25". There was no mixture compensation for altitude with this arrangement. I'm thinking that the lower the stiffness of the diaphram, the more consistency in the setup and responsiveness, while both of these objectives are met. By maximizing compliance of the diaphram, the springs acting in the system are mainly the coil spring and the leaf springs that act to locate the armature. My stainless diaphram is the most compliant, but there is another feature of steel (if I remember correctly) that adds to the argument that this is a late Bosch design- steel has a much higher Youngs modulus than copper. The higher the Youngs modulus, the greater the fatigue resistance, and the vastly most common failure mode of the MPS is fatigue failure. Could this have been a Bosch attempt to solve a reliability problem, even as the technology was being superceded by more modern ones? Since the cells are also subject to fatigue, would they have switched them over at the same time? I am planning on assembling my own personal MPS using the stainless parts, and seeing how close I can tune it to my engine. There are lots of other parts in the MPS that I've formed opinions about, but I'll hold off for now. These are my own opinions, which may not be popular, so BLAST AWAY!! (eye candy below) ![]() |
| pbanders |
Feb 1 2010, 11:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 988 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
Wow, really great info! With your permission and credit to you, can I use some of the photos and data on my MPS page (see link in sig)?
You mention the full-load diaphragm provides altitude compensation. This is only true under heavy and full-load conditions. The only MPS's that provided part-load altitude compensation were the 0 280 100 100 series that was used on the MB's. These units lacked the full-load diaphragm (full-load was sensed by the throttle switch) and had an altitude compensation cell that was connected to the atmosphere through a holow screw. I agree with your observation that the lower the "stiffness", or spring constant of the diaphragm, the less effect it will have on the transition characteristic. For any material used, the thickness and pleat design will vary. Reliability and resistance to fatigue failure is also an important consideration in the material selection. Crafting the aneroid cells out of a different material and/or a different pleat design would be tricky. The issue here is to identically duplicate the pressure vs. displacement characteristic of the OEM cells. It would interesting to compare the SS cells to the OEM cells for this characteristic. Positioning of the full-load stop is also critical to defining the transition region, setting the proper full-load mixture, and reducing the mechanical stress on the full-load diaphragm. Bosch sets most MPS to a 2 in. Hg engagement, though I have seen some units set to 4 in. Hg. Again, great stuff, thanks for sharing it with us. |
| jk76.914 |
Feb 1 2010, 08:46 PM
Wow, really great info! With your permission and credit to you, can I use some of the photos and data on my MPS page (see link in sig)? You mention the full-load diaphragm provides altitude compensation. This is only true under heavy and full-load conditions. The only MPS's that provided part-load altitude compensation were the 0 280 100 100 series that was used on the MB's. These units lacked the full-load diaphragm (full-load was sensed by the throttle switch) and had an altitude compensation cell that was connected to the atmosphere through a holow screw. I agree with your observation that the lower the "stiffness", or spring constant of the diaphragm, the less effect it will have on the transition characteristic. For any material used, the thickness and pleat design will vary. Reliability and resistance to fatigue failure is also an important consideration in the material selection. Crafting the aneroid cells out of a different material and/or a different pleat design would be tricky. The issue here is to identically duplicate the pressure vs. displacement characteristic of the OEM cells. It would interesting to compare the SS cells to the OEM cells for this characteristic. Positioning of the full-load stop is also critical to defining the transition region, setting the proper full-load mixture, and reducing the mechanical stress on the full-load diaphragm. Bosch sets most MPS to a 2 in. Hg engagement, though I have seen some units set to 4 in. Hg. Again, great stuff, thanks for sharing it with us. On the data and photos- you're welcome to them, with one caveat. We're using beryllium in a project at work, and one of the characteristics is that it is transparent to X-rays. So I need to verify that our XRF is capable of detecting Be in alloys. If not, those numbers may not be right. I'm travelling until the end of the week, so it'll be Friday before I can get with the lab guy. We have other means of measuring alloys that I can pursue that don't use X-Rays. The brass and stainless alloys should be correct.... Sorry to everyone if my info was premature. I'll be sure to confirm or correct it shortly. That makes sense about the full load only altitude compensation. The diaphram has to lift off the stop for any compensation to occur.... makes sense. I have a 0 280 100 120 MPS from a Cosworth Vega that is like the MB MPS you described... but then it is, as you said, part of the 100 series... Interesting that Chevrolet licensed the technology directly from Bendix, not Bosch, but all the comonents are Bosch. I measured several (maybe 6) aneroid cells sets using the same MPS, but with the diaphram locked. I set their inductance to a common value at the same vacuum, and then measured and plotted the curves. Their slopes are identical. I plotted them on the same axis, and they are as coincident as I can imagine. These 6 included a set from a 0 280 100 001 (early type 3, no diaphram, probably the simplest MPS out there) AND the stainless steel set. So now I'm setting up to measure the vacuum/L curves for diaphrams alone. I sacrificed a set of perfectly good aneroid cells by cutting them open and filling them with gorilla glue to set them. I let them harden in my vise with the jaws set to original cell dimension (gorilla glue expands when it hardens, and would have pushed them open). First thing I found was that the cells ARE MANUFACTURED WITH PARTIAL VACUUM INSIDE!! As soon as my cutoff blade broke through, they expanded out and became flacid. Anyway, now that they're hardened up, I'm going to measure inductance curves, which will represent the response of the diaphrams alone. I'm thinking that I can combine the diaphram and cell responses using superposition and get pretty close to what the finished MPS should be.... getting interesting. |
| realred914 |
Dec 7 2010, 02:22 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Wow, really great info! With your permission and credit to you, can I use some of the photos and data on my MPS page (see link in sig)? You mention the full-load diaphragm provides altitude compensation. This is only true under heavy and full-load conditions. The only MPS's that provided part-load altitude compensation were the 0 280 100 100 series that was used on the MB's. These units lacked the full-load diaphragm (full-load was sensed by the throttle switch) and had an altitude compensation cell that was connected to the atmosphere through a holow screw. I agree with your observation that the lower the "stiffness", or spring constant of the diaphragm, the less effect it will have on the transition characteristic. For any material used, the thickness and pleat design will vary. Reliability and resistance to fatigue failure is also an important consideration in the material selection. Crafting the aneroid cells out of a different material and/or a different pleat design would be tricky. The issue here is to identically duplicate the pressure vs. displacement characteristic of the OEM cells. It would interesting to compare the SS cells to the OEM cells for this characteristic. Positioning of the full-load stop is also critical to defining the transition region, setting the proper full-load mixture, and reducing the mechanical stress on the full-load diaphragm. Bosch sets most MPS to a 2 in. Hg engagement, though I have seen some units set to 4 in. Hg. Again, great stuff, thanks for sharing it with us. On the data and photos- you're welcome to them, with one caveat. We're using beryllium in a project at work, and one of the characteristics is that it is transparent to X-rays. So I need to verify that our XRF is capable of detecting Be in alloys. If not, those numbers may not be right. I'm travelling until the end of the week, so it'll be Friday before I can get with the lab guy. We have other means of measuring alloys that I can pursue that don't use X-Rays. The brass and stainless alloys should be correct.... Sorry to everyone if my info was premature. I'll be sure to confirm or correct it shortly. That makes sense about the full load only altitude compensation. The diaphram has to lift off the stop for any compensation to occur.... makes sense. I have a 0 280 100 120 MPS from a Cosworth Vega that is like the MB MPS you described... but then it is, as you said, part of the 100 series... Interesting that Chevrolet licensed the technology directly from Bendix, not Bosch, but all the comonents are Bosch. I measured several (maybe 6) aneroid cells sets using the same MPS, but with the diaphram locked. I set their inductance to a common value at the same vacuum, and then measured and plotted the curves. Their slopes are identical. I plotted them on the same axis, and they are as coincident as I can imagine. These 6 included a set from a 0 280 100 001 (early type 3, no diaphram, probably the simplest MPS out there) AND the stainless steel set. So now I'm setting up to measure the vacuum/L curves for diaphrams alone. I sacrificed a set of perfectly good aneroid cells by cutting them open and filling them with gorilla glue to set them. I let them harden in my vise with the jaws set to original cell dimension (gorilla glue expands when it hardens, and would have pushed them open). First thing I found was that the cells ARE MANUFACTURED WITH PARTIAL VACUUM INSIDE!! As soon as my cutoff blade broke through, they expanded out and became flacid. Anyway, now that they're hardened up, I'm going to measure inductance curves, which will represent the response of the diaphrams alone. I'm thinking that I can combine the diaphram and cell responses using superposition and get pretty close to what the finished MPS should be.... getting interesting. if the x-ray window in your instrument is made of berilium, detecting berilium is out of the question. |
jk76.914 MPS- delving into it's secrets? Jan 30 2010, 11:57 AM
Bartlett 914 Great Job! That is interesting information. If... Jan 30 2010, 12:32 PM
underthetire Good work! It was always assumed it was BeCu, ... Jan 30 2010, 01:20 PM
jk76.914
Good work! It was always assumed it was BeCu,... Jan 30 2010, 04:14 PM
detoxcowboy "This came from a rebuilt MPS that was in a p... Jan 30 2010, 11:19 PM
Dave_Darling They gave it the "float test"? ;)
(Mus... Jan 31 2010, 01:21 AM
914Sixer Of the MPS I have taken apart, I have only seen ve... Jan 31 2010, 08:08 AM
pbanders
I measured several (maybe 6) aneroid cells sets u... Feb 2 2010, 09:25 AM
mtndawg This information is great.This is what I've of... Feb 1 2010, 04:31 PM
jk76.914 I'm back. I looked in to this, and unfortunat... Feb 9 2010, 05:49 AM
ArtechnikA
...anyone know how I can go in and edit that post... Feb 9 2010, 06:17 AM
pbanders I used to do a lot of surface analysis when I work... Feb 9 2010, 08:57 AM
pbanders
I used to do a lot of surface analysis when I wor... Feb 9 2010, 09:53 AM
pbanders Also seems like once we get a material and a desig... Feb 9 2010, 10:02 AM
Bleyseng From RustyWa years ago in a PM to me.
"You ... Feb 9 2010, 10:47 AM
pbanders
"You... Feb 9 2010, 10:53 AM
Bleyseng
"Yo... Feb 9 2010, 11:17 AM
Jeff Bowlsby As easy as it would be to make it from pure copper... Feb 9 2010, 02:36 PM
pbanders Jeff's right, pure Cu is very soft. Ever hear ... Feb 9 2010, 05:19 PM
jk76.914 The Niton XL-800 is also an X-ray fluroescence ins... Feb 9 2010, 07:08 PM
Bleyseng yeah but, Eric's testing showed no Be just Al,... Feb 9 2010, 07:20 PM
jk76.914 Quick update. I did the crappy brass characteriza... Feb 11 2010, 04:59 AM
jk76.914 Yesterday during lunch, we tried to press apart a ... Feb 20 2010, 11:43 AM
ArtechnikA
So we sectioned it. Take a look....
As you can ... Feb 20 2010, 02:16 PM
underthetire did the ring seem hard yet gummy when you cut it? ... Feb 20 2010, 12:39 PM
kwales I think yer making this too hard.
I agree with th... Feb 20 2010, 05:19 PM
jk76.914
I agree with t... Feb 21 2010, 07:43 AM
76-914 Great stuff here. I'll bet ya'll will have... Feb 20 2010, 06:58 PM
pbanders Great stuff, a few comments. One, the design of th... Feb 21 2010, 09:23 AM
jk76.914
Great stuff, a few comments. One, the design of t... Feb 21 2010, 12:13 PM
kwales I think they make the PEM's out of the stuff t... Feb 21 2010, 12:05 PM
McMark You guys are awesome for researching this... :notw... Feb 21 2010, 12:09 PM
jk76.914 OK. I took some more photos. These three are cop... Feb 21 2010, 01:49 PM
jk76.914 Picked up a -010 MPS this week, allegedly from a V... Feb 27 2010, 04:57 PM
ArtechnikA
The diaphram hub is idential to stock, which I... Feb 28 2010, 05:16 AM
McMark :trophy: :notworthy: Feb 27 2010, 11:43 PM
rick 918-S Love this science stuff! Feb 28 2010, 12:23 AM
914Sixer Really amazing reading!! :Qarl: Feb 28 2010, 07:35 AM
Thomas J Bliznik
:ag... Feb 28 2010, 08:30 AM
jk76.914
:a... Feb 28 2010, 11:33 AM
pbanders
Anybody have any connections at Bosch?
FWIW, th... Mar 1 2010, 11:20 AM
pbanders It would be great if we could get Bosch to supply ... Mar 1 2010, 11:14 AM
pbanders FYI, are others aware of the Bosch Classic web sho... Mar 1 2010, 11:29 AM
pbanders FWIW, I sent an email to the guy in Bosch Germany ... Mar 1 2010, 06:02 PM
jk76.914
FWIW, I sent an email to the guy in Bosch Germany... Mar 1 2010, 06:30 PM
jk76.914 OK, some images from that -010 Volvo MPS. First t... Mar 1 2010, 06:45 PM
jk76.914 Nice clean housing. Not perfect, but not bad. Yo... Mar 1 2010, 07:09 PM
Bleyseng .
Also found another of those plastic rings... W... Mar 2 2010, 09:21 AM
pbanders FYI, I've made some interesting connections at... Mar 3 2010, 10:48 AM
pbanders OK, here's a bit more info. There's a news... Mar 3 2010, 11:14 AM
kwales While you are on a roll,
Howsabout fuel injectors... Mar 3 2010, 02:18 PM
Howsabout fuel injectors.......
:agree:
We sh... Mar 3 2010, 02:33 PM
pbanders
:agree:
We s... Mar 3 2010, 02:51 PM
jk76.914 Brad's link links to Bosch Traditions, which i... Mar 3 2010, 06:55 PM
jk76.914 Did anybody say throttle position sensor?
Here... Mar 3 2010, 07:17 PM
computers4kids Yikes...that's $218 US dollars :blink:
... Mar 3 2010, 07:39 PM
jk76.914
Yikes...that's $218 US dollars :blink: ... Mar 3 2010, 08:05 PM
computers4kids
[quote name='computers4kids' post='1281997' date=... Mar 3 2010, 10:26 PM
jk76.914 Nevermind. I found the english version at eBay-UK... Mar 3 2010, 08:55 PM
pbanders Yeah, I should have been more clear. I knew the ha... Mar 3 2010, 09:39 PM
Bleyseng Maybe I can send them the box of 50 dead MPSs siit... Mar 4 2010, 01:24 AM
jk76.914 Too bad you can't just get a kit. Diaphram, o... Mar 4 2010, 04:34 AM
McMark Jim, tuning is the real issue with a home rebuild ... Mar 4 2010, 12:33 PM
Bleyseng
Jim, tuning is the real issue with a home rebuild... Mar 5 2010, 09:58 AM
jk76.914
Jim, tuning is the real issue with a home rebuil... Mar 5 2010, 04:56 PM
Larouex
[quote name='Bleyseng' post='1282691' date='Mar 5... Mar 8 2010, 09:29 AM
Bleyseng
[quote name='Bleyseng' post='1282691' date='Mar ... Mar 8 2010, 10:52 AM
pbanders
First you weld a "bung" onto the exhaus... Mar 8 2010, 11:05 AM
jk76.914 I know. But I also I think there's an opportu... Mar 4 2010, 07:53 PM
mtndawg I sent an email to Bosch via the Traditions web si... Mar 5 2010, 09:46 AM
1988Hawk 4 new 2.0 injectors from Otto, not cheap but reaso... Mar 5 2010, 07:03 PM
pbanders Matthias is the same guy I'm communicating wit... Mar 5 2010, 11:06 PM
jk76.914 Exchanged emails with Herr Matthias Klumpp at Bosc... Mar 8 2010, 05:24 AM
ArtechnikA I would be quite surprised if Bosch made a rebuild... Mar 8 2010, 06:07 AM
pbanders
I would be quite surprised if Bosch made a rebuil... Mar 8 2010, 10:36 AM
kconway So if Bosch does a rebuild kit over a complete reb... Mar 8 2010, 11:08 AM
pbanders
So if Bosch does a rebuild kit over a complete re... Mar 8 2010, 11:18 AM
jk76.914
So if Bosch does a rebuild kit over a complete r... Mar 8 2010, 07:49 PM
jk76.914
So if Bosch does a rebuild kit over a complete re... Mar 8 2010, 08:04 PM
Bleyseng Even when Bosch comes out with a new or rebuilt MP... Mar 8 2010, 09:18 PM
3d914 Any update on this? Curious 914 owners are watchin... Oct 17 2010, 11:13 PM
jk76.914
Any update on this? Curious 914 owners are watchi... Oct 18 2010, 03:15 AM
trfrick This is what I received from Bosch regarding rebui... Dec 6 2010, 02:25 PM
r_towle fantastic news Dec 6 2010, 02:52 PM
jk76.914 Well, I guess it's time to get back at this. ... Dec 6 2010, 07:04 PM
jk76.914 I've set aside trying to make diaphrams for no... Dec 6 2010, 07:14 PM
SirAndy I've set aside trying to make diaphrams for no... Dec 6 2010, 09:50 PM
jk76.914 I also toyed with the idea of making a test diaphr... Dec 6 2010, 07:20 PM
jk76.914 Here's a loose end from last spring. I dissec... Dec 6 2010, 07:29 PM
Bleyseng
Here's a loose end from last spring. I disse... Dec 7 2010, 06:35 AM
jk76.914 I know. Something had to give. If I focus on mak... Dec 7 2010, 07:22 AM
Bleyseng
I know. Something had to give. If I focus on ma... Dec 7 2010, 08:46 AM
realred914 looks like i will will be needing to get my mps cl... Dec 7 2010, 02:29 PM
jk76.914
looks like i will will be needing to get my mps c... Dec 7 2010, 08:14 PM
914 shifter diaphram-less MPS that is properly set up with suc... Dec 7 2010, 10:01 PM
bandjoey Yes. I've just read this front to back and it... Dec 7 2010, 10:40 PM
Bleyseng if you are running a stock rebuild motor setting t... Dec 8 2010, 07:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 09:09 PM |
