Out with the old...in with the new...Britain's Racecar Development, Subaru Engine, Lotus Suspension! Time to go racing! |
Britain Smith |
Dec 6 2010, 11:33 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
forcefed |
Dec 7 2010, 02:29 PM
Newbie Group: Members Posts: 8 Joined: 7-October 09 From: CO, rockies and so cal Member No.: 10,901 Region Association: None |
instead of a slip fit , you could add two more bellows, or you can get rid of all your bellows all together and make them all slip fit.
andys |
Dec 7 2010, 04:17 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
instead of a slip fit , you could add two more bellows, or you can get rid of all your bellows all together and make them all slip fit. +1 for the two additional bellows. They'll help alleviate issues with not only expansion/contraction of the header, but also any shift in the turbo location due to slight motor mounting shifts (between routine removal/install); though my personal preference would be to anchor the turbo to the motor. Nice work! Andys |
Lo-Fi Version | Time is now: 6th June 2024 - 05:27 AM |
