> not getting enough fuel pressure. Whats up?, Fuel pump??
RFoulds
post Dec 8 2010, 04:06 PM
914Rennsport
having an issue with fuel pressure. Fuel flows freely from the end of the tunnel lines, connecting to fuel pump. (its a 74 1.8 with stock FI)
fuel pump has been thoroughly checked out and seems to be good. But, fuel pressure is not enough to get a squirt out of the injectors. Instead, while cranking, the fuel is barely dripping out instead of a good spurt.
all fuel lines are new, injector rails are good, injectors all good.
Any ideas what is causing this??
pcar916
post Dec 8 2010, 04:37 PM
Is that a Lola?
If you block the return line and your fuel pressure goes up beyond normal the regulator is bad. But only do it for a moment or two.
- Lo-Fi Version Time is now: 9th July 2025 - 04:50 PM
