RFoulds |
914Rennsport ![]() ![]() ![]() Group: Members Posts: 858 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region ![]() ![]() |
having an issue with fuel pressure. Fuel flows freely from the end of the tunnel lines, connecting to fuel pump. (its a 74 1.8 with stock FI)
fuel pump has been thoroughly checked out and seems to be good. But, fuel pressure is not enough to get a squirt out of the injectors. Instead, while cranking, the fuel is barely dripping out instead of a good spurt. all fuel lines are new, injector rails are good, injectors all good. Any ideas what is causing this?? |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,097 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Ground? On the '75 the fuel pump has its own ground, under the fuel tank just under the driver side of the tank...
Lo-Fi Version | Time is now: 9th July 2025 - 04:39 PM |
