> 1974 1.8L FI Vacuum hoses?
JeffBowlsby
post Dec 10 2010, 10:21 AM
Which of these two diagrams is correct...the top or bottom one?
The difference is the hoses at the dizzy vacuum can...they cannot both be right.
[NOTE: I deleted the incorrect diagram originally posted...the diagram remaining is the correct configuration]
JeffBowlsby
post Dec 11 2010, 09:12 AM
Thanks everyone, looks like the bottom diagram is correct. I will delete the first one out of this post to avoid any future confusion by anyone who finds this thread. Al, your set-up has no vacuum advance, have you tried hooking it up the other way? You may notice a difference on acceleration.
Als914
post Dec 11 2010, 11:16 AM
Lighting my way
QUOTE(Jeff Bowlsby @ Dec 11 2010, 07:12 AM) *
I'll give it a try and report back. Thanks.
Als914
post Dec 11 2010, 11:38 AM
Lighting my way
QUOTE(Als914 @ Dec 11 2010, 09:16 AM) *
You got me wondering so I went out to check my setup and it is correct to the diagram but as mentioned earlier I do not have port #2 on my thottle body. Are you suggesting I reverse the connection at the vacuum advance housing? Yellow hose to where the pink hose is?
Jeff Bowlsby   1974 1.8L FI Vacuum hoses?   Dec 10 2010, 10:21 AM
Als914   My '74, L-jet is set up to the top diagram sin...   Dec 10 2010, 10:33 AM
r_towle   I have tried both on a 76 2.0 liter. For emmisions...   Dec 10 2010, 10:47 AM
Root_Werks   Mine is the bottom since I have two ports on the T...   Dec 10 2010, 10:48 AM
r_towle   Mine is the bottom since I have two ports on the ...   Dec 10 2010, 10:52 AM
Root_Werks   Mine is the bottom since I have two ports on the...   Dec 10 2010, 10:55 AM
Root_Werks   Rich, that's pretty interesting. I have my de...   Dec 10 2010, 10:52 AM
r_towle   Rich, that's pretty interesting. I have my d...   Dec 10 2010, 10:53 AM
Jeff Bowlsby   Uhh, Excuuuuuze me... This is a thread about the...   Dec 10 2010, 11:13 AM
Als914   Uhh, Excuuuuuze me... This is a thread about th...   Dec 10 2010, 11:21 AM
Root_Werks   Sorry Jeff, you're right. My thoughts are tha...   Dec 10 2010, 11:30 AM
dr914@autoatlanta.com   Hi Jeff I replied right away but forgot to hit the...   Dec 10 2010, 11:31 AM
pete000   After Jan 1 1974 the vacuum advance was discont...   Dec 18 2010, 12:59 AM
pete000   After Jan 1 1974 the vacuum advance was discontin...   Dec 21 2010, 06:55 PM
zonedoubt   Probably referring to the 2.0L engine. No 1.8L in ...   Dec 22 2010, 12:45 AM
zonedoubt   I think this discussion would benefit from identif...   Dec 10 2010, 04:05 PM
jsayre914   i am running the bottom diagram on the motor i jus...   Dec 10 2010, 05:49 PM
Sailor   My 74 is set up to the bottom diagram.   Dec 10 2010, 07:56 PM
Jeff Bowlsby   Thanks everyone, looks like the bottom diagram is ...   Dec 11 2010, 09:12 AM
Als914   Thanks everyone, looks like the bottom diagram is...   Dec 11 2010, 11:16 AM
Als914   Thanks everyone, looks like the bottom diagram i...   Dec 11 2010, 11:38 AM
Jeff Bowlsby   Yes...   Dec 11 2010, 03:28 PM
pete000   This is what it should look like if the second vac...   Dec 15 2010, 07:56 PM
Jeff Bowlsby   This is what it should look like if the second va...   Dec 16 2010, 01:13 AM
zonedoubt   A short three inch piece of tubing going no where...   Dec 16 2010, 01:03 PM
Cap'n Krusty   There are some disturbing errors throughout this t...   Dec 16 2010, 02:42 PM
pete000   There are some disturbing errors throughout this ...   Dec 18 2010, 12:50 AM
zonedoubt   ...there's a specific procedure for doing so....   Dec 21 2010, 06:23 PM
zonedoubt   I have seen several Ljet equipped engines with the...   Dec 17 2010, 12:57 AM
pete000   This seems to be a controversial topic ! :cho...   Dec 18 2010, 12:44 AM
zonedoubt   This is probably due to some confusion with 2.0L v...   Dec 19 2010, 10:09 PM
Jeff Bowlsby   We need a 'dog-chasing-his-tail' smiley be...   Dec 18 2010, 01:07 PM
pete000   Here is a photo of my TB on my 74 1.8 L-Jet I am c...   Dec 18 2010, 05:45 PM
zonedoubt   Single port on throttle body to distributor vacuum...   Dec 19 2010, 09:57 PM
zonedoubt   This is a two-vacuum-port throttle body (p/n 022 1...   Dec 19 2010, 10:00 PM
Cap'n Krusty   I've worked on the 1.8s since BEFORE they were...   Dec 21 2010, 06:44 PM
Dave_Darling   Check the position of the vacuum fittings on the t...   Dec 22 2010, 02:11 AM
pete000   Check the position of the vacuum fittings on the ...   Dec 22 2010, 12:42 PM
zonedoubt   Ok let me get this right, if the car came with on...   Dec 22 2010, 02:25 PM
Dave_Darling   I think this could only be proven by looking at th...   Dec 23 2010, 08:29 PM
jim_hoyland   My '75 1.8 L-Jet has the 2 port throttle body;...   Dec 22 2010, 10:51 AM
Root_Werks   :blink: My head hurts.   Dec 22 2010, 03:16 PM
markb   :blink: My head hurts. :agree:   Dec 22 2010, 03:33 PM
pete000   Revisiting this old thread. I have pulled off my...   Oct 6 2015, 01:17 AM
rhodyguy   the portion of the diagram the notes the charcoal ...   Oct 6 2015, 06:57 AM
- Lo-Fi Version Time is now: 27th October 2026 - 08:49 PM
