dem |
Rusty Member ![]() ![]() Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California ![]() |
Drove the 914 to turkey time yesterday, about 50 miles of backroads. Seemed to be runnin' about normal with the usual symphony of only-occasional random backfires and pops. It was, of course, ridiculously fun.
Car sat til I left around 10 PM, and by then it was around 40 degrees outside. Lots of popping and stuttering at part throttle. Full throttle and it was the usual fun excitement. The ride home on the freeway was unpleasant because the 2.7L doesn't need much throttle to keep my little car moving. Could this just be temperature related? Idle jets sized for Los Angeles (where I bought it.)? Otherwise I assume I'm looking at checking for gunk in the idle jets, I assume. This is my first carbed porsche, so I guess it is time to really "grok" them. Is there an obvious "start here carb newbie" direction? Book and/or web site? Googling turns up tons and tons of random stuff. Thanks. |
dem |
I try to drive it to full operating temperature at least once/week, plus I run Seafoam in the gas which does seem to help.
No cylinder was off more than 1 on the airflow meter, but that may have been already compensated for. I am suspicious of the 2 cylinders that don't respond much to the mixture screw - maybe I'll blow some carb cleaner or propane around there and see if something is leaking air. Valves & timing all checked 2K miles ago, pretty confident those are good. Also running Crane XR700 electronic ignition. Just drove it a bunch more, and it is definitely much better when warmed up than it was before, or maybe it is just the placebo effect of spending 2 hours turning screws 1/8 at a time. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 3rd July 2025 - 02:17 AM |
