> 911 9146 engine fan housings, Possible Mismatch??
bcheney
post Dec 12 2010, 09:03 AM
My conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
sixnotfour
post Dec 12 2010, 09:27 AM
The fan and housing are a mate, It is the alternator that is not.
You can add a spacer behind the alternator to make work as this fan assy is the 78/79 small diameter.
Or upgrade the alternator.
If you want an Origonal fan setup I will trade for the one you have.
bcheney   911 9146 engine fan housings   Dec 12 2010, 09:03 AM
jt914-6   I'm using my orignal six fan housing # 901 106...   Dec 12 2010, 09:20 AM
sixnotfour   The fan and housing are a mate, It is the alternat...   Dec 12 2010, 09:27 AM
MDG   Housing number is 930106102OR and you can see it ...   Dec 12 2010, 09:58 AM
sixnotfour   Yes too deep , therfore you need a spacer or corr...   Dec 12 2010, 10:48 AM
bcheney   Do you know what could be used as a spacer if I de...   Dec 12 2010, 11:35 AM
rfuerst911sc   Brian I believe the proper count of shims is seven...   Dec 12 2010, 03:44 PM
tomeric914   Fan housings changed depth as the alternator amp o...   Dec 12 2010, 04:05 PM
Cap'n Krusty   The alternator sits too far back. All the pulley ...   Dec 12 2010, 09:52 PM
Mark Henry   I'm seeing I'll have a similar issue...or ...   Dec 12 2010, 11:40 PM
sixnotfour   9.5mm for your setup - bosch alt/ 930.0R ring ...   Dec 13 2010, 02:57 AM
sixnotfour   Shim count   Dec 13 2010, 03:34 AM
bcheney   As usual...thanks for all the replies everyone. Yo...   Dec 13 2010, 06:52 AM
Mark Henry   As usual...thanks for all the replies everyone. Y...   Dec 13 2010, 08:07 AM
Mark Henry   Here's what I'm talking about, both housin...   Dec 13 2010, 11:01 AM
sixnotfour   Mark , you have an early one (bosch) and a later 7...   Dec 14 2010, 04:57 AM
Mark Henry   So how many amps on the smaller Bosch alternator? ...   Dec 14 2010, 07:25 AM
bcheney   55 amp Bosch alt. uses the shallow housing...5mm m...   Dec 14 2010, 07:40 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:21 PM
