dem |
Rusty Member ![]() ![]() Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California ![]() |
Drove the 914 to turkey time yesterday, about 50 miles of backroads. Seemed to be runnin' about normal with the usual symphony of only-occasional random backfires and pops. It was, of course, ridiculously fun.
Car sat til I left around 10 PM, and by then it was around 40 degrees outside. Lots of popping and stuttering at part throttle. Full throttle and it was the usual fun excitement. The ride home on the freeway was unpleasant because the 2.7L doesn't need much throttle to keep my little car moving. Could this just be temperature related? Idle jets sized for Los Angeles (where I bought it.)? Otherwise I assume I'm looking at checking for gunk in the idle jets, I assume. This is my first carbed porsche, so I guess it is time to really "grok" them. Is there an obvious "start here carb newbie" direction? Book and/or web site? Googling turns up tons and tons of random stuff. Thanks. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Side to side balance is adjusted with the down link on the carb linkage. After the end to end balance is correct I use the pass side for a base, then adjust the other side to it using the barrel nut...it expands or contracts the down link when turned. I back off the driver's side idle adjuster and let the linkage "rest" on the pass side only.
This gets the slop out of the linkage. When right, your "snail" should read the same on all throats from idle till it goes off the scale. That takes care of balance. Then it's time to do the mixture screws again.....then check balance....again. Once done, it will stay set for a years....baring catastrophe. The Tango is a piece of cake by comparison (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 3rd July 2025 - 02:13 AM |
