| bcheney |
Dec 12 2010, 09:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
My conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
| Cap'n Krusty |
Dec 12 2010, 09:52 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The alternator sits too far back. All the pulley shims in the world aren't gonna fix that. The new housing has to be machined to allow the alternator to sit in the same position as the old housing did. The only thing the shims do is adjust the space between the pulley halves to compensate for differences in belt length. They have nothing to do with the fore-and-aft location of the vertical c/l of the pulley.
The Cap'n |
bcheney 911 9146 engine fan housings Dec 12 2010, 09:03 AM
jt914-6 I'm using my orignal six fan housing # 901 106... Dec 12 2010, 09:20 AM
sixnotfour The fan and housing are a mate, It is the alternat... Dec 12 2010, 09:27 AM
MDG
Housing number is 930106102OR and you can see it ... Dec 12 2010, 09:58 AM
sixnotfour
Yes too deep , therfore you need a spacer or corr... Dec 12 2010, 10:48 AM
bcheney Do you know what could be used as a spacer if I de... Dec 12 2010, 11:35 AM
rfuerst911sc Brian I believe the proper count of shims is seven... Dec 12 2010, 03:44 PM
tomeric914 Fan housings changed depth as the alternator amp o... Dec 12 2010, 04:05 PM
Mark Henry I'm seeing I'll have a similar issue...or ... Dec 12 2010, 11:40 PM
sixnotfour
9.5mm for your setup - bosch alt/ 930.0R ring
... Dec 13 2010, 02:57 AM
sixnotfour Shim count Dec 13 2010, 03:34 AM
bcheney As usual...thanks for all the replies everyone. Yo... Dec 13 2010, 06:52 AM
Mark Henry
As usual...thanks for all the replies everyone. Y... Dec 13 2010, 08:07 AM
Mark Henry Here's what I'm talking about, both housin... Dec 13 2010, 11:01 AM
sixnotfour Mark , you have an early one (bosch) and a later 7... Dec 14 2010, 04:57 AM
Mark Henry So how many amps on the smaller Bosch alternator? ... Dec 14 2010, 07:25 AM
bcheney 55 amp Bosch alt. uses the shallow housing...5mm m... Dec 14 2010, 07:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:34 PM |
