boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Today after installing front Konis on the V8 914 , started the car and the water pump hose clamp was loose so it puked out a fair amount of coolant. Added a 50/50 mix. ran the car until warmup and drove the car, cold and rainy weather, so it didn't really get hot. @ 160-170.
Any suggestions that I should do as far purging out any air that might be in the system. Or maybe I don't need to do anything. TIA CCLINV8CANTWAIT |
jridder |
Member ![]() ![]() Group: Members Posts: 136 Joined: 5-May 03 From: Sunnyvale, CA Member No.: 656 ![]() |
No reason to use a 50/50 mix unless you are in Alaska. Straight water cools better than "coolant". User just enought to prevent corrosion. I use a 25/75 coolant/water mix but even less would probably be better.
Jonathan |
Lo-Fi Version | Time is now: 7th July 2025 - 05:06 AM |
