| JeffBowlsby |
Dec 10 2010, 10:21 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,371 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Which of these two diagrams is correct...the top or bottom one?
The difference is the hoses at the dizzy vacuum can...they cannot both be right. [NOTE: I deleted the incorrect diagram originally posted...the diagram remaining is the correct configuration] Attached image(s)
| pete000 |
Dec 18 2010, 12:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
This seems to be a controversial topic ! (IMG:style_emoticons/default/chowtime.gif)
There are a lot of threads on this over on the Pelican Parts site too. Here are just a few: (IMG:style_emoticons/default/popcorn[1].gif) http://forums.pelicanparts.com/porsche-914...-necessary.html http://forums.pelicanparts.com/porsche-914...1976-2-0-a.html http://forums.pelicanparts.com/porsche-914...-hose-help.html Attached thumbnail(s) |
Jeff Bowlsby 1974 1.8L FI Vacuum hoses? Dec 10 2010, 10:21 AM
Als914 My '74, L-jet is set up to the top diagram sin... Dec 10 2010, 10:33 AM
r_towle I have tried both on a 76 2.0 liter.
For emmisions... Dec 10 2010, 10:47 AM
Root_Werks Mine is the bottom since I have two ports on the T... Dec 10 2010, 10:48 AM
r_towle
Mine is the bottom since I have two ports on the ... Dec 10 2010, 10:52 AM
Root_Werks
Mine is the bottom since I have two ports on the... Dec 10 2010, 10:55 AM
Root_Werks Rich, that's pretty interesting. I have my de... Dec 10 2010, 10:52 AM
r_towle
Rich, that's pretty interesting. I have my d... Dec 10 2010, 10:53 AM
Jeff Bowlsby Uhh, Excuuuuuze me...
This is a thread about the... Dec 10 2010, 11:13 AM
Als914
This is a thread about th... Dec 10 2010, 11:21 AM
Root_Werks Sorry Jeff, you're right.
My thoughts are tha... Dec 10 2010, 11:30 AM
dr914@autoatlanta.com Hi Jeff I replied right away but forgot to hit the... Dec 10 2010, 11:31 AM
pete000
After Jan 1 1974 the vacuum advance was discont... Dec 18 2010, 12:59 AM
pete000
After Jan 1 1974 the vacuum advance was discontin... Dec 21 2010, 06:55 PM
zonedoubt Probably referring to the 2.0L engine. No 1.8L in ... Dec 22 2010, 12:45 AM
zonedoubt I think this discussion would benefit from identif... Dec 10 2010, 04:05 PM
jsayre914 i am running the bottom diagram on the motor i jus... Dec 10 2010, 05:49 PM
Sailor My 74 is set up to the bottom diagram. Dec 10 2010, 07:56 PM
Jeff Bowlsby Thanks everyone, looks like the bottom diagram is ... Dec 11 2010, 09:12 AM
Als914
Thanks everyone, looks like the bottom diagram is... Dec 11 2010, 11:16 AM
Als914
Thanks everyone, looks like the bottom diagram i... Dec 11 2010, 11:38 AM
Jeff Bowlsby Yes... Dec 11 2010, 03:28 PM
pete000 This is what it should look like if the second vac... Dec 15 2010, 07:56 PM
Jeff Bowlsby
This is what it should look like if the second va... Dec 16 2010, 01:13 AM
zonedoubt
A short three inch piece of tubing going no where... Dec 16 2010, 01:03 PM
Cap'n Krusty There are some disturbing errors throughout this t... Dec 16 2010, 02:42 PM
pete000
There are some disturbing errors throughout this ... Dec 18 2010, 12:50 AM
zonedoubt
...there's a specific procedure for doing so.... Dec 21 2010, 06:23 PM
zonedoubt I have seen several Ljet equipped engines with the... Dec 17 2010, 12:57 AM
zonedoubt This is probably due to some confusion with 2.0L v... Dec 19 2010, 10:09 PM
Jeff Bowlsby We need a 'dog-chasing-his-tail' smiley be... Dec 18 2010, 01:07 PM
pete000 Here is a photo of my TB on my 74 1.8 L-Jet I am c... Dec 18 2010, 05:45 PM
zonedoubt Single port on throttle body to distributor vacuum... Dec 19 2010, 09:57 PM
zonedoubt This is a two-vacuum-port throttle body (p/n 022 1... Dec 19 2010, 10:00 PM
Cap'n Krusty I've worked on the 1.8s since BEFORE they were... Dec 21 2010, 06:44 PM
Dave_Darling Check the position of the vacuum fittings on the t... Dec 22 2010, 02:11 AM
pete000
Check the position of the vacuum fittings on the ... Dec 22 2010, 12:42 PM
zonedoubt
Ok let me get this right, if the car came with on... Dec 22 2010, 02:25 PM
Dave_Darling I think this could only be proven by looking at th... Dec 23 2010, 08:29 PM
jim_hoyland My '75 1.8 L-Jet has the 2 port throttle body;... Dec 22 2010, 10:51 AM
Root_Werks :blink:
My head hurts. Dec 22 2010, 03:16 PM
markb
:blink:
My head hurts.
:agree: Dec 22 2010, 03:33 PM
pete000 Revisiting this old thread.
I have pulled off my... Oct 6 2015, 01:17 AM
rhodyguy the portion of the diagram the notes the charcoal ... Oct 6 2015, 06:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th October 2026 - 08:49 PM |
