| JeffBowlsby |
Dec 10 2010, 10:21 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,371 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Which of these two diagrams is correct...the top or bottom one?
The difference is the hoses at the dizzy vacuum can...they cannot both be right. [NOTE: I deleted the incorrect diagram originally posted...the diagram remaining is the correct configuration] Attached image(s)
| JeffBowlsby |
Dec 18 2010, 01:07 PM
We need a 'dog-chasing-his-tail' smiley because thats how I feel right now. (IMG:style_emoticons/default/biggrin.gif)
The question is how to plumb distributor advance/retard for the 1.8 L-jet cars? Lets sort this out, I don't have a 1.8L car so I have nothing to refer to - counting on the 914world braintrust to figure it out. "Jim Hoyland...Clay Perrine...Come to the white courtesy phone please" We apparently have two different throttle bodies, one with only one port (#1 on non-pressure side of throttle plate) and another with two nipples (#1 on non-pressure side, #2 on the pressure side of the throtle plate). The distributor vacuum can always has two ports: a 4mm OD advance port (away from dizz) and 5mm OD retard port (towards dizz). I searched the tech sources I have for answers - 2 different Bosch L-jet manuals, the 1974 and 1975 914 Service and Training manuals, the factory 914 repair manual, Harold T. Glenns manual and a privately authored 912E manual (L-Jet) I found on the internet. Only the 912E manual has a vacuum hose diagram (below). Note how the vacuum retard port on the vacuum can is shown connected to the single port throttle body in the diagram. Dr. 914 also suggests that the vacuum retard function is the hose that is connected to the throttle body. Another point of reference is the 1974 and later D-Jet cars with only a single port throttle body (which is a 5mm OD port) - the hose is connected to the retard side of the vacuum can for these cars (also a 5mm OD port). The preponderence of evidence suggests: The vacuum hose on 1.8L single port throttle body (5mm OD) gets connected to the vacuum can retard port (5mm OD)? If so, the second diagram Pete posted would seem to be correct after all. Can someone with a single port 1.8L throttle body verify the port OD size? Is it 5mm OD? Does anyone have a 2 port 1.8L 914 throttle body they can check the port OD sizes? When it is verified, I'll be sure the correct diagram is posted in this thread and on my website for future reference. (IMG:style_emoticons/default/thumb3d.gif) Attached image(s)
| pete000 |
Dec 18 2010, 05:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Here is a photo of my TB on my 74 1.8 L-Jet I am changing out to a Terry throttle cable at the moment and snapped a picture.
Only has the rearward port and it is 5mm. Currently I am running the vacuum line to the retard port. I did notice when I purchased this car it would not idle very well when it was cold and it tended to ping a bit. The hose was to the advance port when I got the car and the retard port went to the manifold which I know was wrong. I replaced all the vacuum lines and AAR valve and it seems happier. Hopes this helps solve this mystery. (IMG:style_emoticons/default/popcorn[1].gif) Attached thumbnail(s) |
Jeff Bowlsby 1974 1.8L FI Vacuum hoses? Dec 10 2010, 10:21 AM
Als914 My '74, L-jet is set up to the top diagram sin... Dec 10 2010, 10:33 AM
r_towle I have tried both on a 76 2.0 liter.
For emmisions... Dec 10 2010, 10:47 AM
Root_Werks Mine is the bottom since I have two ports on the T... Dec 10 2010, 10:48 AM
r_towle
Mine is the bottom since I have two ports on the ... Dec 10 2010, 10:52 AM
Root_Werks
Mine is the bottom since I have two ports on the... Dec 10 2010, 10:55 AM
Root_Werks Rich, that's pretty interesting. I have my de... Dec 10 2010, 10:52 AM
r_towle
Rich, that's pretty interesting. I have my d... Dec 10 2010, 10:53 AM
Jeff Bowlsby Uhh, Excuuuuuze me...
This is a thread about the... Dec 10 2010, 11:13 AM
Als914
This is a thread about th... Dec 10 2010, 11:21 AM
Root_Werks Sorry Jeff, you're right.
My thoughts are tha... Dec 10 2010, 11:30 AM
dr914@autoatlanta.com Hi Jeff I replied right away but forgot to hit the... Dec 10 2010, 11:31 AM
pete000
After Jan 1 1974 the vacuum advance was discont... Dec 18 2010, 12:59 AM
pete000
After Jan 1 1974 the vacuum advance was discontin... Dec 21 2010, 06:55 PM
zonedoubt Probably referring to the 2.0L engine. No 1.8L in ... Dec 22 2010, 12:45 AM
zonedoubt I think this discussion would benefit from identif... Dec 10 2010, 04:05 PM
jsayre914 i am running the bottom diagram on the motor i jus... Dec 10 2010, 05:49 PM
Sailor My 74 is set up to the bottom diagram. Dec 10 2010, 07:56 PM
Jeff Bowlsby Thanks everyone, looks like the bottom diagram is ... Dec 11 2010, 09:12 AM
Als914
Thanks everyone, looks like the bottom diagram is... Dec 11 2010, 11:16 AM
Als914
Thanks everyone, looks like the bottom diagram i... Dec 11 2010, 11:38 AM
Jeff Bowlsby Yes... Dec 11 2010, 03:28 PM
pete000 This is what it should look like if the second vac... Dec 15 2010, 07:56 PM
Jeff Bowlsby
This is what it should look like if the second va... Dec 16 2010, 01:13 AM
zonedoubt
A short three inch piece of tubing going no where... Dec 16 2010, 01:03 PM
Cap'n Krusty There are some disturbing errors throughout this t... Dec 16 2010, 02:42 PM
pete000
There are some disturbing errors throughout this ... Dec 18 2010, 12:50 AM
zonedoubt
...there's a specific procedure for doing so.... Dec 21 2010, 06:23 PM
zonedoubt I have seen several Ljet equipped engines with the... Dec 17 2010, 12:57 AM
pete000 This seems to be a controversial topic ! :cho... Dec 18 2010, 12:44 AM
zonedoubt This is probably due to some confusion with 2.0L v... Dec 19 2010, 10:09 PM
zonedoubt Single port on throttle body to distributor vacuum... Dec 19 2010, 09:57 PM
zonedoubt This is a two-vacuum-port throttle body (p/n 022 1... Dec 19 2010, 10:00 PM
Cap'n Krusty I've worked on the 1.8s since BEFORE they were... Dec 21 2010, 06:44 PM
Dave_Darling Check the position of the vacuum fittings on the t... Dec 22 2010, 02:11 AM
pete000
Check the position of the vacuum fittings on the ... Dec 22 2010, 12:42 PM
zonedoubt
Ok let me get this right, if the car came with on... Dec 22 2010, 02:25 PM
Dave_Darling I think this could only be proven by looking at th... Dec 23 2010, 08:29 PM
jim_hoyland My '75 1.8 L-Jet has the 2 port throttle body;... Dec 22 2010, 10:51 AM
Root_Werks :blink:
My head hurts. Dec 22 2010, 03:16 PM
markb
:blink:
My head hurts.
:agree: Dec 22 2010, 03:33 PM
pete000 Revisiting this old thread.
I have pulled off my... Oct 6 2015, 01:17 AM
rhodyguy the portion of the diagram the notes the charcoal ... Oct 6 2015, 06:57 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th October 2026 - 08:48 PM |
