> Air in 914 V8 cooling system, Need advise....
boxstr
post Mar 26 2004, 10:59 PM
Today after installing front Konis on the V8 914 , started the car and the water pump hose clamp was loose so it puked out a fair amount of coolant. Added a 50/50 mix. ran the car until warmup and drove the car, cold and rainy weather, so it didn't really get hot. @ 160-170.
Any suggestions that I should do as far purging out any air that might be in the system. Or maybe I don't need to do anything.
TIA
CCLINV8CANTWAIT
John2kx
post Mar 28 2004, 04:19 AM
Craig,
Sorry to hear about the blown hose. If your going to the trouble to replace hoses, you might want to look at fittings which screw into water pump and ensure you have something that has a ridge/bung installed that would prevent hose from slipping off in future.
Let me know if you want to see what RH uses and I'll send a pic. Have not had a hose come loose (or off) since day one.
Good luck at track today!
John
- Lo-Fi Version Time is now: 7th July 2025 - 05:26 AM
