small bore, high revving 6, anyone running one now? |
DanT |
Dec 18 2010, 10:12 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I have the chance to acquire an 2.0L 6 case and have thought about building a small bore 2.0-2.5L high revving 6.
Anyone out there running such a combination right now? This would be a street/AX motor. Prefer to do single plug. Most likely use Webers, since MFI parts are getting hard to come by . What combinations of Pistons/cams are you folks using? Pictures of motor builds would be appreciated. Just sliding in a 2.7L CSI motor is also a consideration if the small bore motor becomes too much of a pain. (IMG:style_emoticons/default/biggrin.gif) |
koozy |
Dec 19 2010, 11:45 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I should have saved the 2, 2.4 engines I had. The MFI could have been reworked for less than what it costs to purchase that stuff now.
I was trying to collect enough parts to try a short stroke ST spec build. 66MM crank 89mm P&Cs 10.5:1 Elgin Mod E Cams twin plug 46/40 heads High butterfly MFI Would have been a screamer. But, alas... I ran out of know-how and flipped it all for the 2.7 I am building. I know enough now to lose sleep over it but not so much any more. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:42 PM |
