> Rewiring, Should I go ISIS multiplex or "old school analogue?"
phillstek
post Dec 17 2010, 05:36 AM
As the respray on my car approaches completion it is time to consider what to do about the wiring. Here is a bit of background info that may be relevant.
The car was converted to rhd back in 1988. Part of the conversion involved extending the harness from the fuse box to the instruments, switches and ignition and pulling it over from the left to the right side of the dash. It was always dodgy and I've had a couple close calls with electrical fires as well. The rest of the wiring is original to a certain degree although a lot of the connectors are green/corroded looking. The fuel tank sender plug is cracked and a few wires hang loose here and there. There are relays that don't appear to do anything at all etc etc.
Essentially, I don't want to risk any further incidents and have decided to get the car completely rewired from scratch.
I've had some quotes for a traditional job but for not much more, I can have it done with the ISIS.
I'm leaning heavily towards the ISIS.
Does anyone want to tell me why I shouldn't use it and why I should stay with the old school wiring.
Thanks,
Phil
McMark
post Dec 20 2010, 04:16 PM
914 Freak!
It just doesn't seem like the ISIS saves you much, especially when you factor in cost and installation time. Maybe if we had more complicated wiring, or our cars were bigger. The ISIS system doesn't change the number of wires to the components (taillights, headlights, engine, gauges, etc) it simply allows you to swap the long runs of multiple wires to a long run of a few small wires. The full harness is around 14 lbs. I highly doubt the overall weight goes down much in our cars. I think you would see more benefit by building a replica harness, but with smaller wires for things like gauge signals (OE uses 18g) and leaving off the sheathing.
Lots of work and lots of money for very little benefit. What am I missing?
post Dec 20 2010, 04:42 PM
Resident German
QUOTE(McMark @ Dec 20 2010, 02:16 PM) *
What am I missing?
Apparently, there is a *cool* factor to this that we (you and me) are missing ...
Maybe if they delivered their harness in stainless steel or chrome wrappings. Instant BLING! (IMG:style_emoticons/default/laugh.gif)
phillstek   Rewiring   Dec 17 2010, 05:36 AM
abayer1969   IMHO I say go for the modern harness. I have also ...   Dec 17 2010, 06:01 AM
phillstek   IMHO I say go for the modern harness. I have also...   Dec 17 2010, 06:34 AM
edwin   hi there. I found out today how fun it is fitting ...   Dec 17 2010, 06:37 AM
Hontec   Phil, I decided a while ago to go for ISIS in my ...   Dec 17 2010, 06:38 AM
edwin   Just had a look at the website. I need one of thos...   Dec 17 2010, 07:05 AM
realred914   looked at teh website, whow pretty expensive, adn ...   Dec 17 2010, 11:04 AM
Jeff Bowlsby   All I see is some parts on the ISIS website. What...   Dec 17 2010, 11:16 AM
euro911   I was going to recommend your harnesses Jeff ... y...   Dec 17 2010, 11:52 AM
SirAndy   Does anyone want to tell me why I shouldn't us...   Dec 17 2010, 11:58 AM
phillstek   Thanks everyone. Finding a good used one here is i...   Dec 17 2010, 02:25 PM
Jeff Bowlsby   I have over a dozen stock chassis harnesses, from ...   Dec 17 2010, 03:28 PM
kg6dxn   The ISIS system looks really cool. It also looks o...   Dec 17 2010, 07:24 PM
Jake Raby   I am using the ISIS system in my double cab.. If t...   Dec 17 2010, 08:22 PM
phillstek   Thanks again to all for your valued comments. Ok...   Dec 17 2010, 11:55 PM
SirAndy   but remain open to anything that can convince me o...   Dec 18 2010, 12:55 AM
phillstek   I really haven't made a decision either way as...   Dec 18 2010, 06:12 AM
edwin   You will be much better off if you go with an orig...   Dec 18 2010, 06:56 AM
ejm   From the ISIS installation safety warnings: Sound...   Dec 18 2010, 07:09 AM
phillstek   From the ISIS installation safety warnings: Soun...   Dec 19 2010, 05:56 AM
swl   This has an enormous cool factor to it. If you we...   Dec 19 2010, 08:13 PM
Jake Raby   What I like about Isis is a lesser amount of conne...   Dec 19 2010, 08:20 PM
BIGKAT_83   You could make a network yourself with one of the ...   Dec 19 2010, 08:30 PM
Dr Evil   :agree: I was an avionics tech for 4 years and loo...   Dec 19 2010, 09:16 PM
Jake Raby   :agree: I was an avionics tech for 4 years and lo...   Dec 19 2010, 10:03 PM
Dr Evil   Hmm, then the value of this system goes up conside...   Dec 19 2010, 10:08 PM
Jeff Bowlsby   Hi Phil, I checked my inventory, I do have 2 comp...   Dec 20 2010, 02:33 PM
McMark   It just doesn't seem like the ISIS saves you m...   Dec 20 2010, 04:16 PM
SirAndy   What am I missing? Apparently, there is a *cool* f...   Dec 20 2010, 04:42 PM
swl   What am I missing? Apparently, there is a *cool* ...   Dec 20 2010, 06:31 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:42 AM
