> Brake Pad Expanding Springs, same as 911? NLA??
7TPorsh
post Dec 27 2010, 05:13 PM
7T Porsh
Just started driving the car a bit and noticed the front brakes are a little sticky and one side drags a little bit.
After taking a look I realized and remembered that one of these star clips broke before when I removed the calipers the first time. But it was on the side that wasn't dragging. Dragging side has a clip.
I assume these are required to drive with? or uneven braking?
Car is a 1970. Are these the same for a 911? AA shows part number 901 351 916 16.
Are these used in the rear as well?
Also says NLA but repros going for $8-$10 a piece...seems really high and I need four.
Eric_Shea
post Dec 27 2010, 06:56 PM
PMB Performance
For your car, they're the same as a 66 911 or a 912 with solid rotors. Later springs are wider (later 911 works here).
Fronts and Rears can be had at Pelican. Fronts come in a kit. Rears are springs only:
911-352-951-00 (front kit... this will do both calipers)
311-615-269 (rear spring only)
They ain't cheap but they are necessary. If it's dragging a "little bit" it may just be the pad cavity holding up the pad. This is a good time to get in there and clean out the pad cavity. Check for torn boots, etc.
Dragging is usually because of gummed up pistons or, as George mentioned, bad soft lines (they swell internally). If it's sat for a while, I would check and expect both.
- Lo-Fi Version Time is now: 20th July 2025 - 07:00 PM
