Clutch Tube Repair-Meatball style, Daily driver needs a CT fix w/o welding |
wgwhitney2 |
Dec 28 2010, 11:19 AM
What the What? Group: Members Posts: 35 Joined: 8-November 09 From: Rocklin, CA, Northern California Member No.: 11,020 Region Association: Northern California |
Help!
I had thought the clutch cable had gone when the pedal went to the floor board, but nooooo. Upon inspection, the weld on the rear of the clutch tube has let go! This is on my 1973 1.7L with 252,000 miles on her. I have read the two articles in the Lapuwali classic thread, and those levels of repair are just too involved for me at this time. Anyone have a successful recipe to get the system working smoothly, if not correctly repaired? The car is in what I call a "ready to be restored" state. I have to drive it now as transport, so taking it off the road for an extended time is not an option. Removing gas tanks, dropping engines, blowing out fuel lines...nope. I think the front and middle welds may be ok. The whole tube now flexes (rather than free floats) when I put the clutch pedal in, rubbing up against the shifter linkage. What is this "u-bolt" repair method mentioned in the Classics thread? What type of u-bolt, and where and how are they installed? Would rigging up some fender washer+spacer tube+JBweld monstrosity to take the pressure off the rear tube work? I'm thinking transferring the pressure onto the firewall, and totally off the tube body like it is now. So, hold your nose and suggest an ugly, but effective, fix I can do on my back, on the garage floor, in the cold, with oil and grease everywhere. I promise I will fix it right when I restore my baby to show room glory some of these days. Bill |
Cap'n Krusty |
Dec 28 2010, 01:32 PM
Anything other than a properly welded repair is not a repair, it's a kluge, sometimes called a "white trash repair". Do it right, do it once.
The Cap'n |
Lo-Fi Version | Time is now: 9th June 2024 - 07:52 AM |
