7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
Just started driving the car a bit and noticed the front brakes are a little sticky and one side drags a little bit.
After taking a look I realized and remembered that one of these star clips broke before when I removed the calipers the first time. But it was on the side that wasn't dragging. Dragging side has a clip. I assume these are required to drive with? or uneven braking? Car is a 1970. Are these the same for a 911? AA shows part number 901 351 916 16. Are these used in the rear as well? Also says NLA but repros going for $8-$10 a piece...seems really high and I need four. ![]() |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
QUOTE Is there some kind of plate that wedges in between the piston and the pad? Parts diagrams show a plate. the end of the piston is like a semi circle. You don't need that plate if the pistons are set at the correct 20 degree angle. QUOTE according to the info here are all these the same? this seems ridiculous to me or I am missing something... 66 911 - M-Caliper - Non vented 66 912 - M-Caliper - Non vented 66 911 - M-Caliper - Non vented 70 914 - Rear M-Caliper casting, Larger piston - Non vented = same spring 70 914 - Rear M-Caliper casting, Larger piston - Non vented = same spring Don't know what to tell ya. If the pistons are not set properly, you should probably take everything apart and rebuild. DO NOT try to turn them in the bore. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 20th July 2025 - 06:33 PM |
