| fasthonda |
Jul 26 2009, 10:52 AM
914 Type R ![]() ![]() Group: Members Posts: 146 Joined: 10-January 04 From: Simpsonville, SC Member No.: 1,544 Region Association: None |
I would share my project with the world since I enjoy seeing what others have posted. The 914world has been big help in sourcing info, parts, and the car itself.
I thought about building this car for years, and finally decided to act on it. Recomendations and comments are welcome. Thanks, Michael Project Scope Body: 1973 narrow bodied w/ fiberglass bumpers Engine: Honda S2000 F20C (250 ps @ 8200 rpm) Transmission: Stock Front Suspension: 87 911 front end w/ Bilstein Sports, 22 sway bar Rear Suspension 250 lb springs on bilstein sports, poly bushings Wheels: 15x7 with R compound Brakes: 87 911 Carrera F&R This is how it looked when I first got it. Brought this home from Southern Caifornia. The transport company rolled it up in the yard since it had no brakes. ![]() Repaired hell hole ![]() Reinforced rear suspension console ![]() Removed sound deadening from the floor and prepping for POR15 ![]() Rear fiberglass bumper fitted ![]() I hope to be installing the drivetrain in September, that is if Murphy's law quits getting me. The flywheel from KEP is several thousands too small to fit on the crankshaft so I need to get that resolved first. |
| fasthonda |
Dec 22 2010, 05:25 PM
As promised here are a few detailed pics of the cars current state.
The radiator will be completely shrouded once finished. |
| stewteral |
Dec 27 2010, 10:58 PM
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hey Fasthonda,
I love your converion and compliments on the good work! It's a great conversion idea and with such a stout engine, I'm wondering about supercharging! That you really make it fly! My car is a V8 conversion and I also had to raise the engine cover....it isn't even noticeable! When I noticed your radiator install, I believe I saw that your plan to vent out the bottom of the car. I wanted to pass on that I tried this for a couple years with my car and even with an airdam 2" from the ground and 2 big fans, the car still ran HOT on-track. Most of V8 conversions exhaust out the fenderwells and while it seems to work, the BEST way is our the top of the hood. Check out what bynbad914 has done in the attached photo. My solution is similar ala racing sports cars. Since the Honda won't be producing the heat of my 383 Chevy, a modest opening should to the job. Best of luck, keep the photos coming!! Terry |
| fasthonda |
Dec 28 2010, 04:50 PM
When I noticed your radiator install, I believe I saw that your plan to vent out the bottom of the car. I wanted to pass on that I tried this for a couple years with my car and even with an airdam 2" from the ground and 2 big fans, the car still ran HOT on-track. Most of V8 conversions exhaust out the fenderwells and while it seems to work, the BEST way is our the top of the hood. Check out what bynbad914 has done in the attached photo. My solution is similar ala racing sports cars. Since the Honda won't be producing the heat of my 383 Chevy, a modest opening should to the job. Thanks for the advice Terry. From reading the forums I was aware of this, but not until after I finished my original setup. I gonna give this a try and monitor the water temp closely. It won't take too much to angle the radiator forward and vent out the hood if neccesary. Plently of good deals on Ebay for Louvers. Michael |
fasthonda 914 Type R build Jul 26 2009, 10:52 AM
d914 great engine.....will it fit???? Jul 26 2009, 11:28 AM
Phoenix 914-6GT Nice. Can't wait to see this through. :beer2: Jul 26 2009, 12:02 PM
Chris Hamilton Woah, awesome so far. Can't wait to see the pr... Jul 26 2009, 12:05 PM
Zundfolge Sounds like a real cool project, but what class wi... Jul 27 2009, 10:51 PM
fasthonda
Sounds like a real cool project, but what class w... Jul 28 2009, 05:06 PM
ghuff Any reasonw hy you went F20 over a K series?
Peo... Jul 28 2009, 08:20 PM
Chris Hamilton I think the stock F20C should be enough to make a ... Jul 29 2009, 12:13 AM
396 Great concept ...good luck. Aug 12 2009, 12:42 AM
fasthonda Project update. Things are progressing slow since ... Sep 3 2009, 07:15 PM
grantsfo loving it! Sep 3 2009, 09:06 PM
Chris Hamilton This is looking cool! What clutch/flywheel are... Sep 3 2009, 09:40 PM
fasthonda
This is looking cool! What clutch/flywheel ar... Sep 4 2009, 09:35 PM
Chris Hamilton Does the S2k engine rotate the right way, or do yo... Sep 5 2009, 02:34 PM
Andyrew The stock clutch will be fine till you start tryin... Sep 5 2009, 05:08 PM
Chris Hamilton From the AP2 S2000 I drove, I didn't feel that... Sep 5 2009, 08:45 PM
fasthonda I now have the powertrain in its final position an... Sep 11 2009, 07:47 PM
Chris Hamilton Wow, that's looking good!
I suppose it w... Sep 12 2009, 10:44 PM
Chris Hamilton How's the project going? Oct 3 2009, 10:55 PM
fasthonda
Progress has been ... Oct 6 2009, 05:28 AM
wallys914 Updates please! :popcorn: Jan 9 2010, 01:09 PM
dakotaewing I would suggest that you paint over the POR while ... Oct 4 2009, 10:17 AM
fasthonda To wallys914,
I went thru your build thread. Awes... Jan 9 2010, 05:11 PM
spaceshuttle Like your project. I have 3 conversion cars and am... Jan 10 2010, 08:49 AM
fasthonda Here is my design for stiffening the chassis in be... Jan 28 2010, 08:24 PM
The bars line up at the fire wall for strength an... Feb 18 2010, 06:07 PM
bam914 There is a lot of flex in the front of the car. N... Jan 28 2010, 09:17 PM
fasthonda
There is a lot of flex in the front of the car. ... Feb 18 2010, 08:17 PM
Do you have bars going to the rear?
Not yet. At ... Feb 18 2010, 08:44 PM
Andyrew
For a radiator I plan on using a Honda dual co... Mar 12 2010, 06:24 PM
fasthonda
For a radiator I plan on using a Honda dual c... Mar 13 2010, 04:10 PM
e30driver This is a really cool build, looking forward to se... Feb 18 2010, 08:49 AM
Rand Love the bulkhead engine mount.
Man I would love ... Mar 12 2010, 06:55 PM
TargaToy Any updates on this? Is the motor in and running ... Dec 19 2010, 09:59 PM
fasthonda
Any updates on this? Is the motor in and running... Dec 20 2010, 08:31 AM
jsayre914 :Qarl: Looking good. Cant wait .... Dec 20 2010, 11:50 AM
Andyrew Looking forward to the pics!!! Dec 20 2010, 06:21 PM
TargaToy Very interested. Keep the thread going. I'm ... Dec 20 2010, 09:58 PM
fasthonda
If you roll the inner lip, then 15x7 cookie cut... Dec 21 2010, 08:11 PM
Brett W Yes the 3.2-3.7 will fit with an adapter. There a... Dec 21 2010, 09:44 AM
Andyrew Brett, What are the advantages of a hydro trans? A... Dec 21 2010, 10:31 AM
Brett W There really ain't a benefit to the hydro tran... Dec 21 2010, 03:22 PM
stewteral
When I noticed your radiator install, I believe ... Jan 7 2011, 01:26 AM
J P Stein Best of luck, keep the photos coming!!
Te... Feb 12 2011, 09:32 AM
fasthonda One of my home made GT lid. Engine is tall but st... Dec 22 2010, 05:28 PM
TargaToy Your setup is looking really good. Did you run yo... Dec 22 2010, 08:43 PM
fasthonda
Your setup is looking really good. Did you run y... Dec 27 2010, 06:52 PM
fasthonda Added GT style harness bars. Made from U bolts.
... Dec 27 2010, 07:01 PM
Randal
... Feb 25 2011, 01:31 PM
fasthonda The U bolts are a nice touch.
Did you just bend... Feb 25 2011, 08:57 PM
TargaToy I thought I recognized the Ground Controls. :D ... Dec 27 2010, 09:52 PM
TargaToy Progress report? :) Jan 6 2011, 09:31 PM
wallys914 Any updates? :beer2: Jan 27 2011, 09:59 PM
fasthonda
Not much progress in the... Feb 5 2011, 09:34 AM
396 Congrats on a great looking transplant. I'm su... Feb 12 2011, 08:40 AM
fasthonda Finished the seat install today. Ended up using wi... Feb 12 2011, 04:48 PM
Hontec Just wanted to say that I love to see the F20 in t... Feb 13 2011, 08:34 AM
fasthonda
Just wanted to say that I love to see the F20 in ... Feb 14 2011, 08:15 PM
Brett W The 901 will not do the Honda engine justice. The... Feb 14 2011, 04:30 PM
bam914 I have a 914 trans with a 4.8 final drive if the s... Feb 14 2011, 09:05 PM
fasthonda
I have a 914 trans with a 4.8 final drive if the ... Feb 24 2011, 07:33 PM
bam914
I have a 914 trans with a 4.8 final drive if the... Feb 25 2011, 11:11 AM
degreeoff If you can find me a set of 15x8's straight an... Feb 24 2011, 10:33 PM
J P Stein With your car being considerable lighter than an S... Feb 25 2011, 05:36 PM
fasthonda
With your car being considerable lighter than an ... Feb 25 2011, 09:08 PM
fasthonda
With your car being considerable lighter than an ... Mar 1 2011, 06:23 PM
stownsen914 Gear / S2K / 914 (stock) / gears ... Jul 21 2011, 03:19 AM
J P Stein I had a flipped ZD 3rd gear in the shit box. Upshi... Mar 1 2011, 06:47 PM
J P Stein Here's a V, JUMP!
http://forums.pelicanpa... Mar 3 2011, 10:02 AM
Downunderman You could also try Albins: http://www.albinsgear.c... Mar 3 2011, 01:12 PM
TargaToy Update? :confused: Apr 3 2011, 07:34 PM
fasthonda
Update? :confused:
We have Ignition! Sta... Apr 10 2011, 03:54 PM
bohalrantipol Very Nice build! Any data on temps? May 10 2011, 01:40 PM
fasthonda
Thanks... May 10 2011, 06:59 PM
TargaToy How about some video so we can hear this bad boy r... May 24 2011, 09:08 PM
usa4cheer this has been a really good post, it has inspired... Jun 12 2011, 12:03 AM
fasthonda
this has been a really good post, it has inspire... Jun 15 2011, 03:56 PM
fasthonda I finally took it on the long awaited first test d... Jun 20 2011, 06:49 PM
usa4cheer Can't wait to see it in the rpm stratosphere, ... Jun 20 2011, 07:58 PM
silver74insocal :drooley: great work dude keep going and for pete... Jun 20 2011, 10:26 PM
spaceshuttle Michael,
I have a large aluminum radiator that cam... Jun 21 2011, 04:57 AM
VOX is your car up and running? lets see it in action... Jul 18 2011, 03:44 PM
ChrisNPDrider Sweet :beer2:
I like the red and black!
Red a... Jul 22 2011, 11:36 AM
fasthonda Now that my 3 yearold son is back from his 1 year ... Jul 23 2011, 05:48 AM
Ductech
Now that my 3 yearold son is back from his 1 year... Aug 31 2011, 06:26 PM
fasthonda How the hell do you pawn a kid off to your parents... Sep 1 2011, 06:48 PM
dlo914 +1 for Championship White :) Jul 23 2011, 04:01 PM
Andyrew Painting IS a lot of work! Looks like your mak... Sep 2 2011, 10:15 AM
trojanhorsepower How did I miss this?
Very cool! Sep 19 2011, 05:23 PM
fasthonda update.
I finally finished the paint job and it... Nov 9 2011, 07:52 PM
Randal
update.
I finally finished the paint job and it... Nov 10 2011, 03:40 PM
Andyrew Looks great!
Orange peal can be color sanded ... Nov 11 2011, 04:15 PM
NS914 I have been away from the site and my car too but,... Dec 13 2011, 12:26 PM
VOX any updates? videos? looks great. Feb 16 2012, 06:59 PM
fasthonda
Nothing exci... Feb 20 2012, 06:28 PM
Cracker Great job! I had an AP2 S2K and really liked t... Feb 21 2012, 06:15 AM
westtexass2k I am glad I stumbled across this thread. I have b... Sep 21 2012, 03:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:03 AM |
