| damnfiknow |
Dec 28 2010, 09:12 PM
Member ![]() ![]() Group: Members Posts: 77 Joined: 25-October 09 From: Texas Member No.: 10,980 Region Association: None |
Someone, please, the equation for determining the diameter of a bellcrank to be used on a Weber 40 setup. Standard 914 accelerator cable length/throw (full close/full open) and standard Weber 40 butterfly. Also, anyone know of a source for such a bellcrank? Hope not to have to farbricate one myself. No lathe so will have to be with an electric drill for turning power. Extremely primitive.
| McMark |
Dec 29 2010, 03:49 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I have a hunch that it does not pull equally on both carbs. anyone care to comment on the viability of my set up? Unequal pulling/pushing is unacceptable. You should be able to adjust your carbs so that they hit WOT at the same time and flow the same volume of air at idle. I'm a fan of home built stuff, but you gotta be 100% accurate with this type of thing or you're engine may not run smoothly or you may be tossing money away in wasted fuel. A carb linkage should have ZERO slop or wobble. It should move both carbs equally, and it should be simple. do you think this is a better setup than the hex linkage from cb performance? 100% better. I will NEVER recommend hex linkages again. They are all horrible. Is this what I should be using for my Jenvey's Mr. McMark? I think so. (IMG:style_emoticons/default/sunglasses.gif) CSP's web-site says the linkage fits Weber IDFs, but no word on Dellorto DRLAs. I'm thinking that if CB Performance hex linkage fits both, then the CSP should too. Anyone using this on Dell's? It looks like they'll work. |
damnfiknow Carb Bellcrank Equation Dec 28 2010, 09:12 PM
McMark The absolute best bellcrank I've seen is this ... Dec 28 2010, 09:17 PM
mrbubblehead
The absolute best bellcrank I've seen is this... Dec 28 2010, 11:15 PM
ConeDodger
The absolute best bellcrank I've seen is this... Dec 29 2010, 02:34 PM
anderssj
The absolute best bellcrank I've seen is this... Dec 29 2010, 02:43 PM
biosurfer1 I have the one Mark pointed out and I like it. It... Dec 28 2010, 10:01 PM
McMark I sure do! Dec 29 2010, 01:10 PM
jeffdon
I sure do!
So in this setup, it appears tha... Dec 29 2010, 01:15 PM
mrbubblehead
[quote name='McMark' post='1411156' date='Dec 29 ... Dec 29 2010, 02:23 PM
SirAndy My carbs are absolutly identical, which means the ... Dec 29 2010, 02:24 PM
mrbubblehead
[quote name='McMark' post='1411156' date='Dec 29 ... Dec 29 2010, 02:39 PM
mrbubblehead
I sure do!
do you think this is a better se... Dec 29 2010, 01:32 PM
kg6dxn
I sure do!
do you think this is a better s... Dec 29 2010, 02:16 PM
porschetub
I sure do!
do you think this is a better s... Sep 13 2019, 01:22 AM
Cevan Let me see if I can remember how I did mine. If I... Dec 29 2010, 03:03 PM
azbill Take a look at the Sidewinder bell crank designed ... Dec 29 2010, 05:57 PM
914werke @mcmark In the example pic you provided it appear... Sep 12 2019, 05:21 PM
johnhora Source for the CSP Mark mentioned...
https://www2... Sep 12 2019, 09:53 PM
porschetub
https://www... Sep 13 2019, 01:29 AM
Tbrown4x4
[quote name='johnhora' post='2746671' date='Sep 1... Sep 13 2019, 03:02 AM
Chi-town Type 4 with pancake fan I believe is the applicati... Sep 13 2019, 09:20 AM
914werke I bought Mark's bracket and took the cable up... Sep 13 2019, 09:52 AM
euro911 Wow, old thread.
I used the CSP bell crank linkag... Sep 13 2019, 10:54 AM
Tbrown4x4
I bought Mark's bracket and took the cable u... Sep 13 2019, 05:28 PM
bbrock
@[url=http://www.914world.com/bbs2/index.php?sh... Sep 13 2019, 06:15 PM
Tbrown4x4 Yes, 4 inches overall. That left a nice radius fol... Sep 13 2019, 07:53 PM
porschetub Currently out of necessity building one from a chi... Sep 13 2019, 11:24 PM
porschetub Speedworks (?) have one but its a front mount that... Sep 14 2019, 11:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 03:43 AM |
