Floorpan cross tube thingies, Best way to cut them out? |
campbellcj |
Mar 28 2004, 10:26 PM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I finally made some more progress on the car this weekend -- finished the engine compartment side of the fuel line and Weber fuel bar replacement, redid the rear f/g bumper mountings (dzus) and pulled the seat to begin a bunch of interior stuff.
To mount my new seats, I will need to channel or completely remove the box section that goes across the floor pans (i.e. approx. under your knees). The seats will be on alloy sidemounts that are bolted directly to the floor, which I'll reinforce a bit. Question is, should I hunt down a plasma cutter or cutting torch (i.e. pay a shop) or can this be done decently with what I've got, i.e. just about anything else (cutoffs, grinders, drills, etc)??? (IMG:style_emoticons/default/confused24.gif) I don't want to butcher the floors as they're fairly clean and I don't have a welder, either. (IMG:style_emoticons/default/unsure.gif) Thanks again 914 gurus! (IMG:style_emoticons/default/pray.gif) |
Brad Roberts |
Mar 28 2004, 11:14 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
If you dont fold them forward the seat bottom will sit on it before your holes line up for the bracket.
OH! OH! OH! DONT line the seat up straight with the steering wheel. The left seat bracket needs to be about 1/4 forward of the right seat bracket. If you dont... the high side bolster of you seat will have your right knee hyper extended trying to bend towards the gas pedal...so angle the seat a *little* towards the gas pedal. If you notice.. the steering wheel is not lined up straight with driver.. so the seat position works out perfect even at a slight angle. B |
Lo-Fi Version | Time is now: 9th June 2024 - 05:26 PM |
