| Rod |
Jan 2 2011, 12:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
1973 1.7. Running fine all day, then looses power and starts misfiring... Now trouble starting and when it does it idles, roughly at 2000 rpm..
Condensor?? |
| underthetire |
Jan 2 2011, 02:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
It could simply be points need adjustment. I forget about that cause one of the first thing I did was to put a compu fire in it.
Rod 1.7 broken down Jan 2 2011, 12:15 PM
flash914
1973 1.7. Running fine all day, then looses powe... Jan 2 2011, 12:39 PM
Rod Haven't thought about a pert'. May do now ... Jan 2 2011, 12:50 PM
underthetire I doubt a condesor would do that. Stuck mechanical... Jan 2 2011, 01:14 PM
stewteral
1973 1.7. Running fine all day, then looses powe... Jan 2 2011, 01:21 PM
914 shifter check your grounds may have become loose : Jan 2 2011, 02:23 PM
Rod Thankyou all. Back home now after being recovered... Jan 2 2011, 03:44 PM
xperu
Thankyou all. Back home now after being recovere... Jan 2 2011, 04:25 PM
Rod
Thankyou all. Back home now after being recover... Jan 2 2011, 04:41 PM
detoxcowboy Fix the ignition switch, they fail. My car had bee... Jan 2 2011, 09:28 PM
realred914 the high idle at 2000 rpm is a clue, if it is caus... Jan 3 2011, 01:36 AM
geniusanthony I have found pitted ignition points to strand me t... Jan 3 2011, 08:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 10:23 AM |
