| Rod |
Jan 2 2011, 12:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
1973 1.7. Running fine all day, then looses power and starts misfiring... Now trouble starting and when it does it idles, roughly at 2000 rpm..
Condensor?? |
| Rod |
Jan 2 2011, 03:44 PM
Thankyou all. Back home now after being recovered back home (a 60 mile trip) It's the first time in 3 years that the teener has ever let me down and today it's had it's first journey on a flatbed and it was still getting thumbs up from drivers passing by (IMG:style_emoticons/default/smile.gif)(IMG:style_emoticons/default/smile.gif)
The recovery driver said he was going to try and find one to buy, he loved it so much! My first point of call will be change the points and condenser and I will look at the F.I points. I checked for vac leaks at the roadside and couldn't find anything, but of course I'll cover those bases too.. It had in fact had a set of points and condenser fitted last summer, and as I say it was driving really well and then started to splutter, almost as if the advance in the dizzy was stuck open as underthetyre said above.. It's one of those problems that just needs to be worked through, earths checked etc.. fun fun fun! If the engine is screwed and it's dropped a valve or two I'll get a 2270 hardcore engine bolted up (IMG:style_emoticons/default/smile.gif) I'll run through exactly what happened - it may remind one of you Djet experts of something.. Motorway miles this morning - faultless, running really well for an hour or so, then lost power very briefly and then kicked back in - no problem, weird, but carried on. Then it did it again a bit further on, and jumped from having a rough missfire to running perfectly alternately for about five minutes sitting in traffic.. It was either rough as a bag of cats or perfect. when running badly if I dipped the clutch and revved it it would pop out of its' bad mood and behave again, but only for a short period before it threw it's toys out of the pram again.. so sounds electrical to me.. |
| xperu |
Jan 2 2011, 04:25 PM
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None
Thankyou all. Back home now after being recovered back home (a 60 mile trip) It's the first time in 3 years that the teener has ever let me down and today it's had it's first journey on a flatbed and it was still getting thumbs up from drivers passing by (IMG:style_emoticons/default/smile.gif)(IMG:style_emoticons/default/smile.gif) The recovery driver said he was going to try and find one to buy, he loved it so much! My first point of call will be change the points and condenser and I will look at the F.I points. I checked for vac leaks at the roadside and couldn't find anything, but of course I'll cover those bases too.. It had in fact had a set of points and condenser fitted last summer, and as I say it was driving really well and then started to splutter, almost as if the advance in the dizzy was stuck open as underthetyre said above.. It's one of those problems that just needs to be worked through, earths checked etc.. fun fun fun! If the engine is screwed and it's dropped a valve or two I'll get a 2270 hardcore engine bolted up (IMG:style_emoticons/default/smile.gif) I'll run through exactly what happened - it may remind one of you Djet experts of something.. Motorway miles this morning - faultless, running really well for an hour or so, then lost power very briefly and then kicked back in - no problem, weird, but carried on. Then it did it again a bit further on, and jumped from having a rough missfire to running perfectly alternately for about five minutes sitting in traffic.. It was either rough as a bag of cats or perfect. when running badly if I dipped the clutch and revved it it would pop out of its' bad mood and behave again, but only for a short period before it threw it's toys out of the pram again.. so sounds electrical to me.. I had similar problems when I had FI, it turned out to be my old cracked ignition switch. After buying a new switch, it took me 1 1/2 to replace and I was back in business. P.S. make sure if decide to replace it buy from a repitable vendor, they are not all the same. Guess how I know. Mike |
| Rod |
Jan 2 2011, 04:41 PM
Thankyou all. Back home now after being recovered back home (a 60 mile trip) It's the first time in 3 years that the teener has ever let me down and today it's had it's first journey on a flatbed and it was still getting thumbs up from drivers passing by (IMG:style_emoticons/default/smile.gif)(IMG:style_emoticons/default/smile.gif) The recovery driver said he was going to try and find one to buy, he loved it so much! My first point of call will be change the points and condenser and I will look at the F.I points. I checked for vac leaks at the roadside and couldn't find anything, but of course I'll cover those bases too.. It had in fact had a set of points and condenser fitted last summer, and as I say it was driving really well and then started to splutter, almost as if the advance in the dizzy was stuck open as underthetyre said above.. It's one of those problems that just needs to be worked through, earths checked etc.. fun fun fun! If the engine is screwed and it's dropped a valve or two I'll get a 2270 hardcore engine bolted up (IMG:style_emoticons/default/smile.gif) I'll run through exactly what happened - it may remind one of you Djet experts of something.. Motorway miles this morning - faultless, running really well for an hour or so, then lost power very briefly and then kicked back in - no problem, weird, but carried on. Then it did it again a bit further on, and jumped from having a rough missfire to running perfectly alternately for about five minutes sitting in traffic.. It was either rough as a bag of cats or perfect. when running badly if I dipped the clutch and revved it it would pop out of its' bad mood and behave again, but only for a short period before it threw it's toys out of the pram again.. so sounds electrical to me.. I had similar problems when I had FI, it turned out to be my old cracked ignition switch. After buying a new switch, it took me 1 1/2 to replace and I was back in business. P.S. make sure if decide to replace it buy from a repitable vendor, they are not all the same. Guess how I know. Mike Ah, fascinating - the ignition switch has seemed to be playing up recently - it works, but I have to turn it off and then spin all the way round to get the starter to crank - if you just move from ignition on position to further round nothing happens - it wont crank, I have to turn off and turn all the way round again with more vigour... So when this fault occured this afternoon when sitting at the side of the road I played with the key in the switch backwards and forwards ever so slightly whilst running to see if it cut the engine and it didn't.. so maybe it could be a problem, maybe not?? |
Rod 1.7 broken down Jan 2 2011, 12:15 PM
flash914
1973 1.7. Running fine all day, then looses powe... Jan 2 2011, 12:39 PM
Rod Haven't thought about a pert'. May do now ... Jan 2 2011, 12:50 PM
underthetire I doubt a condesor would do that. Stuck mechanical... Jan 2 2011, 01:14 PM
stewteral
1973 1.7. Running fine all day, then looses powe... Jan 2 2011, 01:21 PM
914 shifter check your grounds may have become loose : Jan 2 2011, 02:23 PM
underthetire It could simply be points need adjustment. I forge... Jan 2 2011, 02:43 PM
detoxcowboy Fix the ignition switch, they fail. My car had bee... Jan 2 2011, 09:28 PM
realred914 the high idle at 2000 rpm is a clue, if it is caus... Jan 3 2011, 01:36 AM
geniusanthony I have found pitted ignition points to strand me t... Jan 3 2011, 08:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 10:23 AM |
